I need help with debugging an Aquaboy DLX 2019
Started by Ariosto, October 07, 2020, 06:50:56 PM
Ariosto
Which problems are common in such cases? The diode perhaps? How can I follow the elctric signal? Tester or audio probe?
Ariosto
Quote from: danfrank on October 10, 2020, 11:08:09 PM
Then the board isn't getting power, that's why the LED won't light.
Figure out why power isn't getting through to the regulator
Ariosto
I´m back. I checked the 9v input from thesocket until Q4 and it was everything OK, then I went to the D1 and D2 and there is no more voltage. Do you think I must replace them?
danfrank
#18
You mean you're getting voltage on Q5? Q5 is the BS250 transistor, it should be passing voltage. If you're not getting voltage on pin 8 of the LT1054, then your BS250 is probably not working
Ariosto
Quote from: danfrank on October 12, 2020, 04:42:00 PM
You mean you're getting voltage on Q4? Q4 is the BS250 transistor, it should be passing voltage. If you're not getting voltage on pin 8 of the LT1054, then your BS250 is probably not working
Sorry, my mistake. I mean, Q5 and not Q4. Noob question again, must I have voltage in D1 and D2 as well? Because I don´t have any.
Ariosto
Quote from: danfrank on October 12, 2020, 11:40:47 PM
See above
Well, I checked the voltages in Q4 and pin8 of IC 7. Both are 9.12 volt.
danfrank
#22
Well that's good!
What I would do is pull out IC7 and then check the diodes with your multimeter.
Even with IC7 out of circuit, you should get around 8 volts around pin 1 of the regulator
Ariosto
Quote from: danfrank on October 13, 2020, 12:37:46 PM
Well that's good!
Well, I pulled off the IC7 as you recommended and the diodes measures 9.15V more or less. But something suspicious happen when I check the voltage in the regulator, because I become again 9 volt IN ALL THREE PINS...... Is that normal?
danfrank
The center pin of the regulator should be ground... 0 volts. You either have a solder bridge or that regulator is bad
Ariosto
Quote from: danfrank on October 13, 2020, 11:24:52 PM
I ´ve already checked and there is any solder bridge. I can only guess that the regulator is bad like you said. I hate desoldering because the risk of damaging the PCB rings is always present. What do you mean? If I make a last test with an audio probe before desoldering could be an option? Is the absence of signal when the pedal is engaged a clear sign that the regulator is the problem?
Ariosto
Well, I received 5 new voltage regulators today and gave them a try, but apparently that´s not the problem because I still don´t have voltage in the PCB......
