Author Topic: A Couple Bass Pedals  (Read 594 times)
storyboardist
  • Solder Ninja
  • David - Woodstock, GA
    • View Profile
    • Perf & PCB Layouts
« on: October 15, 2020, 10:32:50 AM »
Been trying to box up some of my prototype builds lately. First up is my Sunndering bass preamp and DI. It's based on the Sunn S200 preamp, but with JFETs. 3-band EQ + volume control into a simple opamp-based DI. Graphics I just printed on medium weight paper and mod podged onto the enclosure.
(Drilling for the XLR was a PITA since my step bits stop at 3/4" and the hole needed is like .8"  >:( )
Next up is the Hot BOD bass drive, a modified DOD FX91. Used the Demedash Incandenza bypass scheme (555 flipflop to trigger a relay). Faceplate I printed on my resin 3D printer. Built it for a bass player friend who's in a band called "Midwell" so it's appropriately (appunpriately?) named. lol
Guy behind Effects Layouts
  • Electron Doctor
  • Eric K.
    • View Profile
Re: A Couple Bass Pedals
« Reply #1 on: October 15, 2020, 11:01:18 AM »
The knob combo on that first one looks amazing!  Very paw-like.
  • Solder Ninja
  • Dan
    • View Profile
« Reply #2 on: October 15, 2020, 11:07:29 AM »
Very nice, does the foot-switch go through the pcb?
  • Global Moderator
  • Electron Doctor
  • Jimi Lee
    • View Profile
« Reply #3 on: October 15, 2020, 12:10:59 PM »
Man, thatís are sharp. How do they sound?
  • Electron Doctor
  • Felix - Graz, Austria
    • View Profile
    • My blog - in german
« Reply #4 on: October 15, 2020, 01:20:17 PM »
I agree, that looks killer. Also dig the graphics and they came out super clean.
My build docs
My etching tutorial
  • Electron Doctor
  • Stephan Nelson / New Zealand / Aotearoa
    • View Profile
« Reply #5 on: October 15, 2020, 01:48:38 PM »
Excellent stuff and looks to boot! 8)
How does the 'mod podging' of paper work, is that some glue stuff to soften the paper or how does that do? Looks sharp as.
storyboardist
  • Solder Ninja
    • View Profile
« Reply #6 on: October 16, 2020, 11:54:07 AM »
Thanks guys!
Yep. Big ol' hole in the middle of the pcb. Momentary switch goes through it and I use an extra plastic washer to space the enclosure doesn't short the back of the board.
The Sunndering sounds great. Lots of EQ range and a ton of volume. The Hot BOD is great too. Not an over the top drive pedal by any means, but dirties up bass very nicely and the clean blend makes it super versatile.
Mod Podge is a water based glue/sealer/finish. Looks like white PVA glue and dries clear. I brush a coat on the back of the paper, place it, then brush a few coats over the top to give it some durability. You could built it up thick and then flat sand it and clear coat it, but I've been too lazy to do all that. Brush strokes haven't been overly noticeable.
Matmosphere
  • Electron Doctor
  • Matthew
    • View Profile
« Reply #7 on: October 16, 2020, 12:59:45 PM »
Man those look great!! That mod-podge work is way better than I have gotten it in the past, it's really clean and I can see almost no brush strokes.
  • Electron Doctor
  • Lee
    • View Profile
« Reply #8 on: October 17, 2020, 11:04:12 AM »
Dude, that DI bass pre looks the business. I wonder how that would do as a studio bass DI.
Willybomb
  • Electron Doctor
  • Willy, not really a bomb.
    • View Profile
    • RockStarGuitar
« Reply #9 on: October 17, 2020, 06:29:33 PM »
Quote
I hear ya.  I usually grind it out a bit more by circling the drill bit around inside the hole.  Great builds by the way.
storyboardist
  • Solder Ninja
    • View Profile
« Reply #10 on: October 22, 2020, 08:28:41 PM »
Thanks guys!
Thanks man! Low light photography helped hide the brush strokes lol
I've been using it live direct to the PA and with in-ears and there's a decent bit of background noise. It's not been that bad (or the sound guys would definitely have let me know) but with in-ears you hear everything. Though I've just been using a wall wart to power it, so with a better power supply it'd probably be fine. The goal was to create something good for live or studio use.
Yeah I did that a good bit, which helped. But between needing nearly another 1/8" and the tabs that needed filing to fit, I've already bought a stepper bit that goes up to 7/8" lol
