Chunk chunk or Dr. Boogei in a 1590LB
Started by thomasha, October 31, 2020, 05:06:20 AM
thomasha
Hi,
here I made a small layout for the Dr. Boogei to fit a 1590LB.
Instead of trimmers I checked the correct value of the anode resistors with trimmers and used the closest resistor instead. Tone stack was positioned on the side of the box with plastic shaft pots. It ended up too close to the 9v jack. In the end there was much more space available than I expected, could have moved the jack without a problem. Since I couldn't get j201 in the normal transistor package, had to use the SMD one. That required some extra wiring done with resistor legs.
Now the pictures:
Board
Pot positioning inside the enclosure
Inside the box
Final shots
Cheers!
Wow, how cool is that!
rockola
I just love these ship-in-a-bottle builds.
Sent from my Redmi Note 7 using Tapatalk
thomasha
Thanks guys!
This thing sounds brutal! amazing pedal. Lots of feedback when playing right in front o the cab.
Damn, these keep getting more impressive.
One of these days you need to post a picture of all of these together.
I feel inspired to put the smallest circuit I can find into the biggest enclosure I can find, because I'd never be able to do what you do.
holy smokes. yet another amazing build.  no idea how you do that, jaw-dropping every time. excellent etch too
287m
i could never wrap my mind around your builds, so awesome my guy!
Quote from: Matmosphere on October 31, 2020, 06:47:03 AM
+1
Your builds are amazing and inspirational, cheers!
MTK
Invertiguy
Sweet Jesus, that's crazy! Is there any circuit you can't cram into a tiny box? Seriously awesome work man!
Doomsday Devices
Willybomb
studiodunn
That is absolutely insane! Like Anna Nicole Smith insane...and super hot, but still crazy.
