Let's make suggestions on the next Giveaway
Started by madbean, February 10, 2021, 02:59:56 AM
I have one in mind that I already designed and verified last year, but I wouldn't mind hearing suggestions to generate ideas I might not consider otherwise!
Caveat:
It needs to fit in a 1590A or B.
Not too complicated - no analog delays or choruses, etc. It needs to be something straightforward and easy to build with no esoteric parts.
I'd like to do the next Giveaway in March or April so if we start now there's plenty of time.
Torgoslayer
artstomp
Dual buffer or dual boost...one can be use before and the other after the chain or a pedal.
Aentons
I think you should do your own version of a Deluxe Bazz Fuss and call it the Super Bad Mean
vizcities
A simple bass/mid/treble tonestack with a single opamp to make up any gain lost.
Tremster
Something like a bit crusher or the crash sync would be pretty cool. I am always game for a good ring mod too. Although the only one I can think of that is small enough is the Escobedo one and it's hard to get the right IC in through hole.
Color me boring but....
What about a JFET test rig? Something that could be used to match JFETs for a Phase AND.... for Idss, etc. Something slick and useful in Madbean fashion.
This way when the many questions about JFETs are posted, anyone can point to the project and say "Build this and ye shall find the way!"  ;D
I'd like a board that lets me add a clean blend to any pedal.
Or, perhaps a cocked wah.
1590B optical phasor!
Aentons
Quote from: jimilee on February 10, 2021, 02:37:40 PM
Here's an interesting one.. fx90b. It's similar to a phase100 I think
Quote from: Aentons on February 10, 2021, 02:46:11 PM
Will it fit in a 1590b? See, I'm planning a multi and I need something small to fit in there.
Aentons
Quote from: jimilee on February 10, 2021, 02:47:54 PM
There is a lot in there so not sure, here is a gut shot
