Author Topic: Pedalpcb Brown Betty  (Read 559 times)
verr76
  • Transistor Tickler
    • View Profile
« on: March 10, 2021, 05:46:39 PM »
Hello all... hope you're doing ok in these times...
havenīt been around here for some time īcause ... well .. 2020 happend  ;D
Got this pedalpcb Brown Betty sometime last year and finally got it done.
Did some mods with the internal trimpot puting it on a daughterboard also in series with a fixed 33K resistor and a second offboard pot to add some control over the added gain.
At the same time the footswitch adds a series resistor and cap to ground on that same opamp's feedback loop. The Change is not drastic but you certainly feel some extra umff
Edit: Small demo (not all things are chunk hehehe)
« Last Edit: March 12, 2021, 07:44:14 PM by verr76 »
Note to self: Fingers are not heat sinks!
  • Electron Doctor
  • Chris
    • View Profile
Re: Pedalpcb Brown Betty
« Reply #1 on: March 10, 2021, 06:37:43 PM »
That looks fantastic, and your wiring is beautiful. What amp are you using this with? I've never tried a friedman amp or pedal but this makes me.want to try one.
Invertiguy
    • View Profile
« Reply #2 on: March 10, 2021, 07:41:35 PM »
Great work, that's some of the cleanest wiring I've ever seen! I love the graphics as well, is that a faceplate or some sort of decal?
harryklippton
  • Solder Ninja
  • Will
    • View Profile
« Reply #3 on: March 10, 2021, 08:07:21 PM »
Wow nice work
  • Global Moderator
  • Electron Doctor
  • Jimi Lee
    • View Profile
« Reply #4 on: March 10, 2021, 08:17:31 PM »
That does look great. I've got the BEOD pedal that sounds killer, never heard a Dirty Shirley.
  • Electron Doctor
  • Dan
    • View Profile
« Reply #5 on: March 11, 2021, 09:00:39 AM »
Very nice work, the friedman stuff is pretty good sounding. This is my go-to for the chunk chunk stuff.
verr76
    • View Profile
« Reply #6 on: March 12, 2021, 01:33:30 PM »
Thank you all for those kind words.
My set up is with a Quilter 45 Microblock most of the time with a preamp of my own design... although, this preamp is in a pedal format so I can also go straight to the Quilter if I need.
It is a faceplate. It's UV printed so I could've easily gone with a direct to enclosure print... but I like the way the raw aluminum looks.
