Rehousing into Boss Enclosure?
Started by soggybag, June 27, 2021, 12:20:25 AM
soggybag
I was thinking about rehousing something into a Boss enclosure. Anyone here done this?
I've seen a couple of these. Switching could either be a relay bypass or a 3PDT switch. I've seen some pictures where a 3PDT switch was fit under the Boss foot pedal/battery door. I'd like to hear how this worked out from anyone who has tried it.
I've done it with a 3dpt. You need to use one of the low profile ones that love my switches sells, and have an extra washer or two. It takes some tweaking but you can hold it in place with two of those plastic washers. Once you get it set up you just have to adjust the bottom nut to the right heights.
One of these days I might make a 3D printed part to fit it in there better.
The soft relay with the boss switch would be way easier.
