2015 Smoothie - not enough phase
Started by slacjs, July 12, 2021, 12:28:00 PM
Zerro
#15
Great! So 4V7 zener gives 4,3V with current consumption. Now, if you have a some more patience, I shoul try here zener 5V1. Little higher voltage at center bias doesn't harm. Try this and we will see. If nothing happens, you should little lower that R19 - 3M9, at cca 3M3 or 2M7. Every j-fet has slightly another thrashold for good functionality. But, maybe that with those 2 phase stages you can't await something more. So, try those tricks, fiddle about bias trimmer, and refer us about. Here are some more tricks, we can still try.
Yep, the phase 45 is exact half of a phase 90. It's very subtle at its deepest.
Zerro
For distorted guitar it would be enough, to hear. Something like wah pedal with low resonancy. Very soft phasing with fuzz or similar fx.
danfrank
My 2¢ worth:
I had a pair of fets that were matched down to 0.003 volt and used them in the Smoothie and the effect is pretty pronounced for a two stage phaser. JimiLee is correct, it's a fairly subtle phaser but if you have a bunch of fets to get a really tight matched pair, that will help. Also, the trimmer to bias the fets is super sensitive. A 10 turn trimmer will help get the best biasing
Quote from: danfrank on July 26, 2021, 11:46:13 PM
My 2¢ worth:
Truth. I put j201s in the last phaser I built. Works really well. I've never heard of a 10 turn trimmer. Sounds handy though.
danfrank
These are actually 3 turn but better than a single turn. Mouser has actual 10 turn trimmers
Quote from: danfrank on July 26, 2021, 11:59:13 PM
Gotcha, thanks.
