Author Topic: Warning about VFE switching PCB (Use the correct RELAY.)  (Read 2413 times)
nimbleswitch
  • Diode Destroyer
  • I make myself rich by making my wants few.
    • View Profile
    • Nimbleswitch
« on: August 29, 2021, 11:59:50 AM »
tfl;dr:
Be careful when subbing out similar relays. Don't use a "2 coil" relay.
Nothing bad will happen, it simply won't work.
Simple version: don't use the series with "L2" in its name.
I tried Panasonic TQ2-L2-5V, when the correct relay was out of stock,
and it didn't switch. (Actually, it would switch between effect and silence but never dry bypass.)
I swapped the relay with the specified TQ2-L-5V
and it works great! One "L," not two baby.
And that's the only thing I changed so I'm pretty sure that was the culprit.
Captain Obvious, out!
« Last Edit: August 29, 2021, 12:13:45 PM by nimbleswitch »
I've got one hand in my pocket, and the other one is waving a dildo.
alamondm
  • Diode Destroyer
    • View Profile
Re: Warning about VFE switching PCB (Use the correct RELAY.)
« Reply #1 on: November 10, 2022, 11:54:05 AM »
I just did the same thing and couldn't figure out why I couldnt get a clean signal. Glad I found your post. Just ordered correct relays.
nimbleswitch
  • Diode Destroyer
    • View Profile
    • Nimbleswitch
« Reply #2 on: November 10, 2022, 06:23:40 PM »
Glad it could be useful!
I should mention, on this particular pedal, the LED comes ON when the pedal is OFF and OFF when the pedal is OFF.
Probably not related to the relay issue, but I figured I should mention it in case you experience something similar.
(In my case, I think it's because I used a PEDALPCB main board with a VFE relay bypass, and I probably just wired something incorrectly.)
  • Electron Doctor
    • View Profile
    • Project Website
« Reply #3 on: November 11, 2022, 06:45:49 AM »
The ONLY saving grace with these relays is that they're relatively easy to desolder and still work.
Don't ask me how I know...
Bust the busters, screw the feeders
