Any Advice on What to Look for in a Magnifying Lamp?
Started by Aviator18, September 24, 2021, 01:50:00 AM
Aviator18
I soldered my first PCB today and determined I need better light and magnification (my eyes aren't as good as they were 30 years ago).  Any advise on what to look for in a magnifying lamp or one you would recommend?
Quote from: Aviator18 on September 24, 2021, 01:50:00 AM
This has been a topic more times than I realized. Here is what Brian is using (or the link to the topic, I need to look into one too.
https://www.madbeanpedals.com/forum/index.php?topic=27403.msg265383#msg265383
harryklippton
I switched to lighted magnifying lenses last year. I prefer them to the lighted magnifying lens and found I don't have to crane my neck so much
Aviator18
I started with a gooseneck magnifying glass with a built-in light. Worked pretty well, although I have to hold my head at the right place and the right angle, and you have to work around it with the soldering iron and solder.
I was later gifted a head mounted magnifying set with built-in light. Much easier to work with, although the extra weight takes a little bit to get used to. You can do whatever you want with your iron and hands.
Quote from: alanp on September 24, 2021, 05:53:31 AM
This, had one, the magnifying lamp is just a pain to use, always in the way, always needing to be adjusted, moved, my shops well lit and i use a headband binocular magnifier that pivots up out of the way when i don't need it, easy to use even with glasses and always there wherever you turn your head to look.
This is the one i've been using for many years, lots out there to choose from.
Aviator18
I got a lighted head set coming and a 5x Magnifying Lamp. I need a lamp anyway, so I might as well get one with magnification.
Aviator18
Got these today:
https://www.amazon.com/gp/product/B071GWM9QN/ref=ppx_yo_dt_b_asin_title_o04_s01?ie=UTF8&psc=1
The difference is night and day! I can see a great deal more detail and makes the job much easier.
Ooh nice. I need some more of those. I use mine a lot, mostly for troubleshooting. The rest of the time, I use reading glasses.
Vivek_rc
I have one of these and find it very useful. Take a bit getting used to when soldering but it's become a useful tool.
Aviator18
Wow, that surely makes it easy to read resistor values. ;D
