Author Topic: Noob Attempts Pedal Build...Coloursound One Knob Fuzz Reissue...Now With Pics!  (Read 4066 times)
burnt fingers
  • Diode Destroyer
    • View Profile
NOT mine, obviously  ;D
This is where I am aiming, in terms of skill level and neatness....just a beautiful build in my eyes! Wires obviously not at 90 degrees BUT stiffer wire and so neat/tidy!
  • Global Moderator
  • Electron Doctor
  • Jimi Lee
    • View Profile
Nice. Zip ties!
burnt fingers
  • Diode Destroyer
    • View Profile
Yup!
Stiffer wire, zip ties and just super neat and tidy!
  • Electron Doctor
    • View Profile
The wire you want is 22g pre-tinned.  It holds its shape. If you check Small Bear, they might have some left.
I'd also recommend getting some 24g for tighter builds like 1590As
Zerro
  • Solder Ninja
    • View Profile
For the best reliability is more usefull soft and light cord with silicon isolation. Only one wire is more inclinable to break when some shock during transport.
"Nudíte se? Kupte si našeho cvičeného ježka! Pobaví vás svými veselýmí kousky!"
burnt fingers
  • Diode Destroyer
    • View Profile
UK based, sadly....
Will look into it though....some 24g? Not sure what that is, sorry, Noob here!
  • Electron Doctor
    • View Profile
The numbers are the gauge of the wire. 24 has a smaller diameter (easier to bend) than 22.  I prefer the 22 but a lot of builders like 24.  I have some 24 for tight builds because sometimes the 22 is too bulky.  There should be a source for it in the UK. I was going to post a link to Small Bear link for reference, but their site seems to be down at the moment.  Here's a link to GuitarPCB's 24g wire as an example.
https://guitarpcb.com/product/barrys-best-pedal-hookup-wire/
burnt fingers
  • Diode Destroyer
    • View Profile
Cool! Thank you! I thought it must be that, just wasn't sure as I am used to seeing .24mm or the like.
Appreciate it!
Zerro
  • Solder Ninja
    • View Profile
At second page of this thread I sent you table metrum.png. With gauges of all 3 types.
burnt fingers
  • Diode Destroyer
    • View Profile
Hi, I did see that....I understood the column with mm...As for the rest of it?
I know nothing remember  :)
Can you explain the relevance please?
Zerro
  • Solder Ninja
    • View Profile
A.W.G - American wire gauge (USA)
S.W.G. - Imperial standard wire gauge (british)
B.W.G. - Birmingham wire gauge (british)
If you are from USA, you will mostly encounter with A.W.G. Most of differencies are not so big as you see.
burnt fingers
  • Diode Destroyer
    • View Profile
Cool...I am in the UK.
burnt fingers
  • Diode Destroyer
    • View Profile
Anyone one from here based in the UK and using 0.24mm? Having a hard time finding it!
And the mail has been and gone without my missing parts...Joy!
SCORE!
Postie came back having realised she had a package for me!!!!
« Last Edit: October 01, 2021, 09:14:14 AM by burnt fingers »
  • Electron Doctor
  • dave - Hamilton ON
    • View Profile
SCORE!
0.24mm  would be extremely tiny in terms of what we use, that would be ~31awg size, the bigger the number the smaller the wire.
22awg is 0.644mm, 24awg is 0.5mm, so anything in that range would be ideal, solid core if you must have 90 degree bends that hold their shape, the more forgiving, stranded with zip ties if a more fluid/organic set up is fine. PTFE/Teflon insulated is a bonus for either solid core or stranded.
And if going with the 90 degree bends get yourself a pair of conical tipped needle nose pliers, wide range of radii and not going to knick weaken the wire when you bend it. Bought mine at a craft store selling jewellery making supplies.
« Last Edit: October 01, 2021, 10:26:42 AM by davent »
burnt fingers
  • Diode Destroyer
    • View Profile
SCORE!
Still trying to figure out what I want if I am honest. The 90 degree thing isn't major, more the rigidity of the wire. I have 22AWG right now and I am not really loving it. it's not hideous BUT, would prefer something a little more rigid!
Ta for the input, appreciate you taking the time!
I do need to go get some better tools this weekend...mine are a bit 'pants!'
Didn't like the first one, made another...Will eyeball later for any errors re parts, found 2 on the first board  :(
All a learning curve right?
