Lectric-FX Flintlock Flanger (A/DA Flanger)
Started by benny_profane, November 11, 2021, 08:51:42 PM
benny_profane
Quote from: Govmnt_Lacky on November 18, 2021, 12:01:08 PM
Make sure you can find those MN3204 chips first! They are very, very scarce right now  :(
Good call. Yeah that might be a prohibitive one. Do you have any sources you can vouch for?
Quote from: benny_profane on November 18, 2021, 02:51:33 PM
Unfortunately no. Everywhere I have gone before seems to have supplies dried up  :(
benny_profane
Quote from: Govmnt_Lacky on November 18, 2021, 04:00:04 PM
Ah, that's a drag. I'll have to do some research before embarking on that one in that case.
harryklippton
This build report has convinced me I need to build this pedal
benny_profane
danfrank
#20
Nice!
This project also works really well with the MN3004 BBD. Clock needs to be adjusted and the clock cap needs to be upped to 27-30pf to get the frequencies correct. 20-800kHz clock range, 40 to 1! You can go down to 17kHz for a slightly wider sweep but watch for noise on the low end of the sweep.
Oh yeah, the MN3004 is 14 pin and MN3007 is 8 pin, just chop the extra legs off the MN3004...
