Author Topic: My foray into eagle and the results.  (Read 989 times)
  • Global Moderator
  • Electron Doctor
  • Jimi Lee
    • View Profile
Re: My foray into eagle and the results.
« Reply #15 on: November 22, 2021, 09:27:03 PM »
Very nice!
And bonus points for the resistor teepee!  :D ;D
:D Thanks you. Being my first attempt, I wanted to remove all variables that could make it not work, otherwise I would've used what ever I had kicking around. They all pretty much fired right up, I had to use a couple of jumpers on the PG14 for traces that didn't get connected.
  • Electron Doctor
  • Aotearoa
    • View Profile
    • http://alanp.info/
« Reply #16 on: November 23, 2021, 01:01:08 AM »
Those layouts are pretty slick!
Only thing I'd suggest is making the traces thicker.
  • Global Moderator
  • Electron Doctor
  • Jimi Lee
    • View Profile
« Reply #17 on: November 23, 2021, 09:09:23 AM »
Thank you. How do you do that in Eagle? I can google it, but if you know right off, and how much thicker.
  • Electron Doctor
  • Aotearoa
    • View Profile
« Reply #18 on: November 23, 2021, 10:34:12 PM »
I usually use about 0.4064mm for signal traces, next step up if I can get away with it. Don't know what that is in Victorian England units, sorry :) :P :)
Forgot to mention, I also love how you've integrated the indicator LED for the stompswitch in the same place on each board!
  • Global Moderator
  • Electron Doctor
  • Jimi Lee
    • View Profile
« Reply #19 on: November 24, 2021, 09:47:24 AM »
Gotcha, and thank you. The LED is easier for me to work with when it’s that low. It’s also easier not using an LED bezel.
