Author Topic: 3pdt wiring and IO  (Read 1308 times)
okfb
  • Diode Destroyer
3pdt wiring and IO
« on: February 15, 2022, 03:46:39 PM »
Hi everyone!
I'm currently working on my first project and even though i surfed through many schematics of wirings i still don't understand how exactly does it work, especially led implementation :( Could anyone explain it to me?
Also i was about to use io from mbp library and ran in the same problem... How does led resistor should be mounted? Should L pad and led cathode be traced and anode conected to ground? Thanks in advance!
p.s sorry for any spelling mistakes i might have made....
Aentons
  • but..but.. why?
Re: 3pdt wiring and IO
« Reply #1 on: February 15, 2022, 04:01:23 PM »
Did you see the "Footswitch Wiring Essentials" in the tutorials section?
https://www.madbeanpedals.com/tutorials/downloads/MBP_FootswitchWiring.pdf
Aentons
  • but..but.. why?
« Reply #2 on: February 15, 2022, 04:04:31 PM »
It doesn't matter which leg of the LED the current limiting resistor (CLR) goes to. The short leg (negative / cathode) of the LED always goes to ground and the long leg (positive / anode) always goes to you positive power supply line.
« Last Edit: February 15, 2022, 04:08:09 PM by Aentons »
okfb
  • Diode Destroyer
« Reply #3 on: February 16, 2022, 09:09:32 AM »
This guide really helped!!! Thank you!!!
