Author Topic: MBP Bass Compressor Recommendation  (Read 260 times)
benny_profane
  • Electron Doctor
    • View Profile
« on: May 09, 2022, 08:16:29 AM »
I'm looking to round out a bass pedalboard build. On my guitar board, I use an optical comp; I've had decent results using it with bass. Since there have been a bunch of new comp offerings recently, I'm wondering which would be best suited for bass. I typically play fingerstyle but do use a pick occasionally. I'm more interested in a subtle smoothing rather than dramatic pumping.
  • Electron Doctor
  • Matthew
    • View Profile
Re: MBP Bass Compressor Recommendation
« Reply #1 on: May 09, 2022, 08:36:49 AM »
I use a Bear Hug most of the time, it's pretty subtle and works well on bass in my experience. But if I were you I might wait until Brian comes out with the new Oracle compressor. I used to use a boss comp on bass and really liked it.
benny_profane
  • Electron Doctor
    • View Profile
« Reply #2 on: May 09, 2022, 09:47:55 AM »
Nice, thanks for the recommendation. I'm not familiar with the CS-3. Is it a Ross derivative? How is the knee characterized?
  • Electron Doctor
  • Chris
    • View Profile
« Reply #3 on: May 09, 2022, 11:22:52 AM »
I'm using the kompromat on everything. I love it. IMO it's the best for every use. The blend makes it as subtle or intense as you want and unlike other ota comps, Brian used the barber tone press circuit so it doesn't pump on high compression rates. Killer comp.
  • Global Moderator
  • Electron Doctor
  • Jimi Lee
    • View Profile
« Reply #4 on: May 09, 2022, 11:48:16 AM »
Compressors ate what brought me into the diy world of pedal building. I’ve found bass compressors to be a “to taste” pedal. I’ve built literally dozens, here’s where I got. Bass optical compressors aren’t great for live performances, the sound loses that sparkle, probably from being in the moment and playing a little harder than normal. I’ve played just about all of the diy compressors and landed on an EHX soul preacher. The bear hug would work about the same.
benny_profane
  • Electron Doctor
    • View Profile
« Reply #5 on: May 13, 2022, 10:14:35 AM »
Great suggestions. Thanks. Interested to check out the Kompromat. I was assuming that FET comps would be the majority suggestion, so it's interesting to see an OTA design working well.
I think the main issue I've run into with compressors and bass is that the amplitude of the low end ends up overtaking the detection and eats up the high end. I know a blend is typically used to address this, but I'm interested in other solutions as well. A HPF sidechain seems interesting. Has anyone successfully implemented one in a comp design?
  • Electron Doctor
  • Eric K. (personal pronouns: he/him)
    • View Profile
« Reply #6 on: May 13, 2022, 11:55:41 AM »
This compressor is quite excellent for bass (I used it when I gigged):
http://www.thatcorp.com/pedals/4316%20Battery-Powered%20One%20Knob%20Squeezer.pdf
benny_profane
  • Electron Doctor
    • View Profile
« Reply #7 on: May 13, 2022, 12:05:40 PM »
This looks interesting. Is there a board available for this project?
  • Electron Doctor
    • View Profile
« Reply #8 on: May 13, 2022, 12:19:32 PM »
Not that I'm aware of.  I built mine on vero.
benny_profane
  • Electron Doctor
    • View Profile
« Reply #9 on: May 13, 2022, 12:28:05 PM »
Nice! What quad op-amps are you using there?
  • Electron Doctor
    • View Profile
« Reply #10 on: May 13, 2022, 12:36:45 PM »
TL074 for both.  No need for anything fancier.
