TS808 gain not working, everything else works.
Started by Jay, July 14, 2022, 03:03:53 PM
Jay
Everything works but the gain knob. Volume adjusts the volume, tone adjusts the tone, the gain pot does nothing.
Anyone have any ideas as to why?
Name of the circuit = TS8 (oh) 8
https://rullywow.com/wp-content/uploads/2022/07/TS8oh8-v2.pdf
No modifications to the circuit and no parts substitutions.
Q1
C = 8.43
B = 3.54
E =3.14
Q2
C= 8.43
B= 3.54
E= 3.14
IC1
1= 4.20
2= 4.20
3= 4.20
4= 0
5= 4.20
6= 4.22
7=4.20
8= 8.43
This smells like a bad connection issue. Suggest you use the DMM to check connections in the Drive portion of the circuit (everything coming off of Pins 6 & 7 of IC1)
My guess is that you will find a bad solder joint or bad/broken connection/trace. Also check your resistor and cap values are correct.
Good Luck  ;D
Gotta have pictures of both sides. Close up and clearly lit.
