Author Topic: How to solder SMD components  (Read 3497 times)
  • Electron Doctor
  • Dan
    • View Profile
« on: July 14, 2022, 01:48:24 PM »
I have been asked this a few times by viewers of the channel and decided to make a video on how I smd solder with just a standard solding iron. Hope you all like it and have a great weekend!
  • Electron Doctor
  • Stephan Nelson / New Zealand / Aotearoa
    • View Profile
Re: How to solder SMD components
« Reply #1 on: July 14, 2022, 03:03:45 PM »
Great video! And bang the FV-1 is on, no sweat.
The only thing I do differently is adding liberally liquid flux with flux pen and clean off after that with alcohol.
  • Electron Doctor
  • Dan
    • View Profile
« Reply #2 on: July 14, 2022, 03:57:38 PM »
Thank you! With adding the flux and using the alcohol does it leave any residue behind or stickiness?
  • Electron Doctor
    • View Profile
« Reply #3 on: July 14, 2022, 06:39:25 PM »
Not with the one I use, the flux is pretty thin and watery, so easy to clean off.
Hefty
  • Transistor Tickler
    • View Profile
« Reply #4 on: July 15, 2022, 10:46:36 AM »
Nice video, what temp to you like to run your iron at and do you have a tip type you like to use?
  • Electron Doctor
  • Dan
    • View Profile
« Reply #5 on: July 15, 2022, 01:03:52 PM »
Great question! I use a Hakko fx-888D and run it at 750 degrees. I use the standard thin tip not like pencil thin but thinish.
Hefty
    • View Profile
« Reply #6 on: July 16, 2022, 10:29:27 AM »
That is the same Iron I have. Is it the standard tip that comes on the Hakko FX-888?
  • Electron Doctor
  • Dan
    • View Profile
« Reply #7 on: July 20, 2022, 01:41:11 PM »
Yes it is, i for some reason cannot remember the tip name
mattc
  • Stompbox Star
    • View Profile
« Reply #8 on: July 20, 2022, 05:27:57 PM »
That seems a lot less daunting now.   Thanks!
  • Electron Doctor
  • Dan
    • View Profile
« Reply #9 on: July 21, 2022, 05:38:58 AM »
If I can do it anyone can, its super easy once you get the hang of it.
marks
  • Diode Destroyer
    • View Profile
« Reply #10 on: November 04, 2022, 09:49:10 PM »
Looks great, thanks for sharing. Similar no-nonsense method I did in this video.
I've gotten endless messages about using flux, though, as I'm guessing you have too. Here's a quick follow up that's the same basic method but with paste type flux for smoother and quicker joints: https://youtu.be/YsB2gPcPRWY?t=165
thomasha
  • Solder Ninja
  • Thomas
    • View Profile
« Reply #11 on: November 05, 2022, 06:04:01 AM »
Nice one. Thanks for the video!
Much easier than suffering while holding the chip in position with tweezers.
Do you have a suggestion of how to solder SMD small-ish resistors?
It's a nightmare. Too much pressure on the tweezers and they fly away and I have to look for them on the carpet.
If you know of a better way of handling such parts it would be very helpful!
  • Electron Doctor
  • Dan
    • View Profile
« Reply #12 on: November 05, 2022, 08:34:06 AM »
I do not have an effective method at all for resistors, I still live in the land of through hole resistors
jessenator
  • Electron Doctor
  • (un)Professional Hobby Collector
    • View Profile
« Reply #13 on: November 05, 2022, 09:45:05 AM »
In taking apart and re capping vintage computers, I discovered that factories would often use a small dab of glue for things like smd can caps. Not sure if they did that for other components as well…
It's a pain, full stop. Many folks in the vintage computer repair world have microscopes or magnifying goggles to aid in positioning and even then a steady and patient hand is required (something I really struggle with).
Whatever you do, don't use those (forgive me if there's a proper word) reverse sprung tweezers to hold parts! Learned that the hard way. I find it helpful to gently scoot parts instead of picking them up like a crane, if that makes any sense.
I've had luck with tantalum smd caps this way: put down flux (the proper answer yo 'how much?' is always "yes") then tin the pads, just like jjjimi84 did, and use what solder is there to just get one side soldered on (properly aligning the part, of course), I've found it helpful to gently press down on the part to make sure it's not "floating". Once that side is secure, solder the other side. IME if you tin the pads just right you won't need to add any additional solder, leaving you an extra hand for tweezing.
thomasha
  • Solder Ninja
  • Thomas
    • View Profile
« Reply #14 on: November 05, 2022, 04:58:46 PM »
Quote
Yes, otherwise some weird stuff happens. When the parts are really small the have their own will, and sometimes that means 90 degrees to the solder pad.
It must be something with the wettability of the solder, because if you don't press them down they will just turn up or get stuck to the soldering iron. I will try using glue to position them first.
