Author Topic: aria ad-10 analog delay  (Read 493 times)
Hefty
  • Transistor Tickler
« on: July 17, 2022, 11:57:19 AM »
Working on a aria ad-10 analog delay and wondering if any one has one, had one or knows anything about one?
I know this is long shot but hell we went to the moon right. Any owner manual or schematic would help.
Hefty
Re: aria ad-10 analog delay
« Reply #1 on: August 14, 2022, 11:21:27 AM »
So I have most of the issues with this pedal fixed, but have one left. When I first plug in the power cord and start playing, the pedal bypasses the guitar like it is suppose to. As soon as I activate the pedal the delay works and if I use the switch for the second function and  hold down the pedal switch and activate the second setting on the delay every thing works as it should. but once I activate the pedal the go back to bypass mode the delay stays on no matter what. If I unplug power the bypass works again the first time and then after delay stays on always. So the pedal uses a surface mounted 4069U for switching between modes. Also 2SK30a JFETs for switches. Is maybe the 4069U have an issue or any other ideas.
