Blue Morning Build Doc updated
Started by jimilee, September 30, 2022, 04:30:18 PM
If you got a Blue Morning PCB from me, I updated the build doc. You may need to download it again. I just realized the SPDT need to be PCB mount (pins) instead of lug the lug mount.
Willybomb
Hey Jimi, How did you go about drilling the two holes for the clipping switches?  They're pretty close in the doc, and tayda's drill service won't allow the two holes to be touching (which happens if they're larger than 3mm in this case).
I might have to get Tayda to drill them out at 3mm and open them up myself with the step drill.
Quote from: Willybomb on November 21, 2022, 09:54:53 PM
When I originally put it together, I hadn't planned on using both switches, one or the other. I'd you use them both, you need to use the PCB mount instead of the lug mount. That's the only way they will both fit. Sorry about that. So many people offer both in KoT fashion. I was after a V4 version of the morning glory.
