that shouldn't do that, should it?
Started by jessenator, November 02, 2022, 09:44:01 PM
jessenator
Friend from the UK sent me a newer BOSS pedal which only worked on battery power. I think I found the reason:
https://i.imgur.com/dnx1MOR.mp4
works on an adapter when the board isn't getting drawn like a bow...
Definitely going to redo the barrel jack soldering and I might also remove those front ground(?) contacts if I can get away with it.
Between the remote bit inside, and the connectors, it's a lot of force pushing on that PCB.
"All you need is fuzz"   ~not Lennon
Aleph Null
Quote from: jessenator on November 02, 2022, 09:44:01 PM
Wow! Wouldn't have expected that from BOSS. Good thing you caught it before the board cracked.
which model is it?
Check the orientation of the I/O jacks and check for any components fouling before you get the soldering iron out
https://www.gigaheartsfx.com
instagram @gigahearts_fx
Quote from: LaceSensor on November 02, 2022, 11:50:44 PM
which model is it?
The Boss Catapult. It's able to launch guitar picks at least 10 feet!
jessenator
Quote from: lars on November 03, 2022, 12:11:57 AM
;D
which model is it?
Definitely! Yeah, I wondered if things might've been shoved in there a bit faster than QC could check it, er whatever. I can't blame them, they're probably worked very hard.
It's a Boss/JHS Angry Driver JB-2. I thought it was going to just be a cracked solder joint or something, but I can't see any hairlines. Might reflow it all the same.
Friend sent it, as I had never used one before, and he knew I tinker around with sort of thing, though with these SMD boards anymore I get super nervous.
jessenator
Well, LaceSensor I took another poke and managed to re-arrange a few wires and connectors and while it still bows—not nearly as bad as before, but still does—but does work again fully assembled. I might need to take it for a longer test drive to see if it holds up for longer.
Like I said, I've never used this one before, and while I like the Blues Driver side well enough on its own, it's overall too crunchy for me. Like a toffee that's been cooked a bit too long, it doesn't have a pleasant breakup on either of J->B  B->J series settings. The parallel one is interesting, but on the whole it hasn't grown on me. Okay, enough of me sounding like a youtubist.
Nice, I've been interested in one of those myself.
classic example of 10 pounds of shit in a 5 pound bag lol
