Dan Boost BC108 PTP Boost
Started by jjjimi84, December 05, 2022, 04:44:32 PM
Here is my point to point boost build report and play through. I love this pedal for when I want that kind of screaming Super Reverb sound but just through my Allen Accomplice. It hammers the front end of the amp and is really biting and cleans up beautifully. I built a Dam Red Rooster boost, I believe, on a breadboard and started swapping things around tinkering around with it using my SG and this was the end result. I wanted a way to try and use up this bag of 200 BC 108s I have had forever, so I thought it would be really cool to try to come up with a simple boost and then pair it with a great BC108 fuzz and make a dual pedal. That pedal is built and in this video and could not have happened without Cooder, I will be filming a video on that soon.
https://youtu.be/18ieK7VOocw
Here is the schematic;
https://www.dropbox.com/s/8mnunvodraip99l/Dan%20Boost.pdf?dl=0
Nice job as always Dan!
Aleph Null
Looks great—especially the angry transistor. How did you go about planning your layout?
Quote from: jimilee on December 05, 2022, 07:39:15 PM
Thanks mate! I appreciate it!
Quote from: Aleph Null on December 05, 2022, 08:24:38 PM
I pot in the pots and switch and the power jack and ran the wires through the holes and wired up the switch. From there I just went for it starting at the power jack and bent the components as I went and soldered them in. Its such a basic boost that it was pretty easy to do. The update version with a bias trimmer and three diodes would be a bit more involved.
That's just bat shit crazy cool.  I may have to throw in the towel if I have to start thinking in 3 dimensions 😉
blackhatboojum
Your point to point is tight and that art is awesome!
The kind of guy who sticks a fork in his Dr. Pepper... If you know what I mean.
jessenator
That is sweet! I love the 3D pipes screensaver vibe going on with the guts :D
Man, that thing is sweet!  8)  Killer build and great video, Dan.
Thank you all very much, it really wasn't to challenging to build. I think every one should try it just once.
God damn the pusher man
