Author Topic: Just a little weener  (Read 7709 times)
  • Administrator
  • Brian
    • madbeanpedals
Re: Just a little weener
« Reply #15 on: January 01, 2012, 09:13:09 PM »
wicked,  awesome work Brian do you have a schematic handy please?  :-*
I would love to breadboard this and see what the fuss is about cheers  ;)
Sure. I'm not positive that the SAG control will be included. I realized after testing my build out that I was actually running it at 6.3v (it was hooked into an LM317) and it sounded awesome. I'm going to do so more tests tomorrow to decide if there is any benefit to lower voltages or not. Everything else is for sure.
« Last Edit: January 03, 2012, 06:34:20 PM by madbean »
jstbrowsin
  • Transistor Tickler
« Reply #16 on: January 01, 2012, 10:10:52 PM »
nice, thanks Brian.
Just out of curiosity are the transistor choices because that's just what you had handy? I'm only asking because Q1 is a 2N3565, google says 2N3904 replacement but I'm not so sure cause there seems to be quite a bit of difference between the 2 specs. What spec (hfe, current gain, impedance etc) should I be looking at specifically to identify the ideal replacement please?
TIA
Haberdasher
  • "El Duder-ino"
« Reply #17 on: January 01, 2012, 10:47:02 PM »
another great project!
Will this layout have pads for radial caps as well, or should I commence to orderin axials?
FABBED PCB's FOR SALE:
Now carrying Matched JFETS
  • Global Moderator
  • Jacob - SK, Canada
    • JMK PCBs
« Reply #18 on: January 01, 2012, 11:00:28 PM »
nice, thanks Brian.
TIA
You could just get a 2N3565 from Smalbear...
  • Sunday Handwired - Sunday Handwound
    • Sunday Handwired Amps and Effects
« Reply #19 on: January 01, 2012, 11:35:21 PM »
very cool. first I've heard of the whipple inductor. Does anybody sell TDK-alikes?
I have modded a dozen or so Vox V847's with Whipple inductors and can say that they are really good.  The guy that makes them is really great to deal with too.  if you look at smallbear they have a variety of inductors too, but no TDK clones are out there to my knowledge.  Sometimes you see a TDK in a fasel style package that has been pulled from an organ on ebay.
In His service.
Magnolia Hill Market Garden
saxoftenest
« Reply #20 on: January 02, 2012, 11:23:59 AM »
YES!!!! Cannot wait for this one...
cjkbug
  • cory
    • My Tattoo Shop
« Reply #21 on: January 02, 2012, 02:06:16 PM »
the "stack of dimes" inductors that small bear sells sound fantastic as well.
  • Administrator
  • Brian
    • madbeanpedals
« Reply #22 on: January 02, 2012, 03:47:48 PM »
nice, thanks Brian.
TIA
I indicated 2n3565 simply because it is what I used and my preference for medium gain transistors (part aesthetics, too which you will see when I post my build pic). You can certainly use a 2n3904 in its place. While I haven't compared the datasheets, they both fall into the ~300 Hfe range.
  • Administrator
  • Brian
    • madbeanpedals
« Reply #23 on: January 02, 2012, 10:12:10 PM »
Okay, so I'm ditching the sag control. No benefit, unless you really love lower output.
The only change will be the suggestion of a socket for the Q1 emitter resistor. Lowering it gives you more volume and gain, if you want it. I settled on 150R. You can go as far as grounding the pin, if you want.
So, just got grease up the treadle tomorrow and it should be good to go.
JakeFuzz
  • Paul
« Reply #24 on: January 03, 2012, 03:38:10 PM »
So does that output buffer mean it will play nice with my Fuzz Faces? So incredibly ready for this thing!
  • Administrator
  • Brian
    • madbeanpedals
« Reply #25 on: January 03, 2012, 06:11:46 PM »
Maybe not all fuzzes. Fortunately, it is easy to bypass and the doc will have instructions on how to do that with a switch.
  • Administrator
  • Brian
    • madbeanpedals
« Reply #26 on: January 03, 2012, 06:37:07 PM »
After looking at some shell specs, I realized that the mounting hole arrangement was not too great on the previous layout. So, I went ahead and revised it to fit the three most common mounting areas in the Crybaby. It actually is a bit better layout in some ways.
Couple small changes to the schem and I went ahead and added the pads for a buffer bypass instead of some kind of kludge....just cleaner this way.
sgmezei
  • Scott- AB, Canada
« Reply #27 on: January 03, 2012, 08:11:43 PM »
This is looking great Brian! I am not sure about the Halo inductor pinout from Small Bear but I think I might use that one. Will there be pads for it? If not, I shall rig something up, or just get the whipple.
  • Administrator
  • Brian
    • madbeanpedals
« Reply #28 on: January 03, 2012, 08:18:03 PM »
Pin spacing on these inductors is a bit hard to come by. I did the Whipple directly from mine, and the Fasel is about 12.5mm. Unfortunately, Steve doesn't seem to provide pin spacing on the other inductors he has.
If anyone has specs on other inductors, please feel free to pass it along and I will do my best to include them.
  • Administrator
  • Brian
    • madbeanpedals
« Reply #29 on: January 04, 2012, 11:50:11 AM »
Here is the final build. Note all my mounting hackery from poor planning (I have since fixed the mounting hole positions). Sound is great....very WAAAHHH. I'm going to tweak the emitter resistor of Q1 a little more and play with the peak trimmer, but everything works and sounds as it should. I opted not to have a bypass for the output buffer on this one. Most likely I will build a couple of these in the future.
Video demo coming ASAP.
