Collosalus Build
Started by Ny_racer_xxx, December 25, 2022, 10:30:40 PM
Ny_racer_xxx
I did a scratch build that turned out pretty good, my buddy wanted one, and I wasn't doing another scratch build.  Finally the boards were in stock, so here I go....
jessenator
Can't wait to see the final builds in their enclosures :)
Been thinking about a flanger, but haven't pulled the trigger yet. Too many other builds in flight.
"All you need is fuzz"   ~not Lennon
Ny_racer_xxx
Quote from: jessenator on January 02, 2023, 12:50:36 AM
Everything was going fine until I put it in the enclosure!!!   I was going batty trying to trouble shoot, bad solder joint? Bad chip?
I went through the excellent trouble shooting guide, sound going into TP1, nothing coming out on TP2.  A few IC's had weird voltages, popped them out one at a time, popped them in my scratch build, no issues.  Started check transistor voltages, found Q2 out of whack and had the same voltage on the collector and emitter looking like a short in the transistor.  Pulled Q1 and Q2, tested them, Q2 was deff bad, tested new ones and replaced both.  BINGO!!!  All is right in the world again!!!
FYI Brian, the way you mirrored the pin assignments on IC7 CD4013 on the schematic, was driving me crazy!!
Quote from: Ny_racer_xxx on April 07, 2023, 01:45:04 AM
Sorry about that. Here it is expanded out if that helps.
Ny_racer_xxx
 No problem, found the bad transistor, working as it should...
Now question for you.  Looks like you added an opamp stage to the NE5532?  What was the reason for that?
To my ears, the original sounds thicker, it's pretty easy to bypass that stage and make it like the original.
Quote from: Ny_racer_xxx on April 20, 2023, 12:16:02 PM
The original MXR used one op-amp shared between the LFO and the audio filtering coming out of the BBD. For the 2022 version I split that into two different op-amps then used the free one as an input buffer to the circuit. I suppose I could have made that part switchable. Actually had not occurred to me.
The reason I added the buffer is that it can sometimes prevent any ticking one might have with LFOs/modulation circuits.
Ny_racer_xxx
#6
Quote from: madbean on April 20, 2023, 12:36:20 PM
Thank you for that explanation!!!  Very much appreciated....
I was just trying to compare what is different from 2022 to the 2015 prototype board I built.  The power supply is slightly different from your designs as well. Minimum filtering, no diodes or caps on the input side of the regulator, and just a 100u cap on the regulated side...  I like using a diode for reverse polarity safety...
I'll experiment and report back.
CR
Ny_racer_xxx
Spenzerleehorton
Im building the collosalus 24 version and noticed the extra IC on input, i had a few silly issues like wiring the wrong pot in the wrong place but apart from wait for IC5 LM1458 (im using a 5532 at the moment to test)
need to go through the volatges again now as i did have the regen pot wired as a 500k rather than a 50k and the sweep/rate as 50k rather than 500k.
regen pot still doesnt seem to do anything and the overall effect isnt very prominent?
the sweep of the phaser is much slower now and starting to sound like the 2015 version.
