Mini Mu Help
Started by rhaas, June 03, 2023, 06:49:03 PM
wizestwizard
Quote from: rhaas on June 07, 2023, 06:43:35 PMOne breakthrough, though the mystery continues...
I didn't think I had any other single op-amps on hand but then I realized that I had a CA3130EZ. I popped it in and that solved the voltage readings on pins 1 and 5 of the IC! Pin 6 was still off (more on that later) but I figured I'd plug in and give it a shot.
The pedal basically works now. I built a Naughty Fish a few years ago so I'm familiar with what to expect from all the knobs and switches. I noticed a bit of extraneous interference-type noise which was probably just due to the open enclosure. However, there's a lot of scratchy/static noise when I turn the level knob. Maybe this is related to the fact that I'm seeing DC voltage (~4v depending on level knob setting) on pin 6 (output).
So two questions remain:
1. What's the likely source of the DC voltage on pin 6, and is there any chance this is related to the CA3130EZ substitution?
2. How in the world did I end up getting two OPA134s from Mouser that didn't work correctly? I've ordered parts from them for years without encountering this kind of problem. I can't imagine that these are fakes (see pictures).
Thanks again, everyone!
Ok I missed this... that solved my voltage issue but not the overall problem I'm having.
