Author Topic: Source for Low Profile / Low ESR Electrolytic Caps? I CANíT FIND ARRGGG!  (Read 396 times)
blearyeyes
  • Electron Doctor
    • View Profile
    • Musical Endeavors
I searched, everywhere, including this forum. I canít seem to find them anywhere.
Most are 11mm tall. What is considered ďlow profileĒ???
My head is going to explode.
Does anyone have a source?
A way to search? Low profile gives no returns.
jessenator
  • Electron Doctor
  • (un)Professional Hobby Collector
    • View Profile
  • Electron Doctor
    • View Profile
    • Project Website
Re: Source for Low Profile / Low ESR Electrolytic Caps? I CANíT FIND ARRGGG!
« Reply #2 on: November 19, 2023, 06:43:31 PM »
Yeah Mouser has been go to.  Anything in particular that I might have kicking around?
Aentons
  • Electron Doctor
  • but..but.. why?
    • View Profile
« Reply #4 on: November 19, 2023, 09:11:26 PM »
I've noticed more caps marked as low impedance. Are those the same as low esr?
blearyeyes
  • Electron Doctor
    • View Profile
    • Musical Endeavors
« Reply #5 on: November 20, 2023, 12:34:28 AM »
I tried to read up about ESR and there is a math equation that includes a bunch of stuff. Resistance is part of it. There is TAN with a squiggly icon after it which is an indicator. I guess it matters what the circuit is around itÖ I donít know.
blearyeyes
  • Electron Doctor
    • View Profile
    • Musical Endeavors
« Reply #6 on: November 20, 2023, 01:45:41 AM »
Thanks Gordo, I think I got it sortedÖ
blearyeyes
  • Electron Doctor
    • View Profile
    • Musical Endeavors
« Reply #7 on: November 20, 2023, 01:49:06 AM »
The low-profile caps I have are just under 6mm (can't make out the brand mark), but these Panasonic's are listed as 5mm length. Length is what you want to search, and it seems that around 5mm height is what you need to be "low profile"
https://www.mouser.com/ProductDetail/Panasonic/ECE-A1CKS220B?qs=rMMd5vBiahpb8aNMFglKXw%3D%3D
IDK if this link will work, but here's the search I did:
https://www.mouser.com/c/passive-components/capacitors/aluminum-electrolytic-capacitors/aluminum-electrolytic-capacitors-radial-leaded/?diameter=4%20mm~~6.3%20mm&length=5%20mm&voltage%20rating%20dc=16%20VDC~~450%20VDC&instock=y&rp=passive-components%2Fcapacitors%2Faluminum-electrolytic-capacitors%2Faluminum-electrolytic-capacitors-radial-leaded%7C~Voltage%20Rating%20DC%7C~Diameter
That is a great link thanks Jessenator! Iím gonna save that and stock up.
blearyeyes
  • Electron Doctor
    • View Profile
    • Musical Endeavors
« Reply #8 on: November 20, 2023, 02:04:56 AM »
Another crazy long link. Anything between 5 and 7mm length is what you want. But, also be careful of the larger values. 100uF low profile gets pretty chunky.
https://www.mouser.com/c/passive-components/capacitors/aluminum-electrolytic-capacitors/aluminum-electrolytic-capacitors-radial-leaded/?diameter=4%20mm~~6.3%20mm&lead%20spacing=1.5%20mm~~2.5%20mm&length=5%20mm~~7%20mm&product=General%20Purpose%20Electrolytic%20Capacitors&termination%20style=Radial&voltage%20rating%20dc=16%20VDC~~50%20VDC&instock=y&rp=passive-components%2Fcapacitors%2Faluminum-electrolytic-capacitors%2Faluminum-electrolytic-capacitors-radial-leaded%7C~Length%7C~Voltage%20Rating%20DC%7C~Lead%20Spacing%7C~Diameter
Low ESR is a different matter. However, I do have a link for a low profile low ESR cap I've used often!!
https://www.mouser.com/ProductDetail/80-ESY276M025AC2AA
Thanks Brian, your link helped me reverse engineer Mousers search engine. Then after getting things one piece at a time, searching and orderingÖI noticed your link to the shopping cart in the docs. Figures!!Ö hehe 😜
