2024 outlook
Started by madbean, January 23, 2024, 01:53:01 AM
Hirti
Awesome, excited for this! Will there be an option to build some of these into 125B enclosures with top jacks?
Quote from: Hirti on February 04, 2024, 02:02:07 PM
Not for the Standard Series. Those are designed specifically for the 1590B. Some of the might be able to go in a 125B with top jacks, but a number of the designs have electrolytic caps near the top edge of the board so top jacks won't fit.
But, one cool thing about them is they will be easy to fit as dual pedals in a 1590BB. So, if you want to build a dual out of any of them they should fit perfectly. I may design an optional bypass board just for that, too. Just haven't done that yet.
jessenator
Quote from: madbean on February 04, 2024, 11:57:02 PM
This is the hot sh*t, right here
Actually, 125BB with top jacks for the duals, I think. Might be possible to do 1590BB with side jacks but then the bypass switches have to be moved close together. With 125BB everything lines up just right.
BricksnBeatles
Quote from: madbean on February 05, 2024, 12:34:39 AM
What about 1590BB2? Does the extra height help top jacks much for how you're planning it?
With the double bypass switch, how about an order switch between the two footswitches too?
Quote from: BricksnBeatles on February 05, 2024, 02:04:40 AM
I don't think Tayda carries the 125BB so maybe the 1590BB2 is the alternate choice. Perhaps the 1590BB itself is possible with the Lumberg jacks turned sideways. I'll need to check into all that.
I think the order switch thing would work out pretty well. But, it is a bit of a pain to bypass if you don't want to use it.
jessenator
I was going over the height specs for the Archibald with a friend, and here are the two compared height-wise for the Archibald's breakout board:
This is the 125BB, a.k.a. the 1590BBS
And the 1590BB2
jessenator
#37
Maybe I'm off the mark here with my interpretation of the want.desire/ask, so take this with a grain of salt.
This is a worst case scenario in the 1590BB2; board/component height based on 90* PC pin pot mounting; jack drilling on max spacing without hitting the inner part of the lid
6x11mm caps in blue
lumberg KLBM-3 jacks
1590BBS / 125BB with 90* rotation on the jacks
I think it'll depend on the population.
edit: fixed 1590BBS image to account for lid collision
Quote from: madbean on February 05, 2024, 03:15:38 PM
Maybe a slide switch would be better?  I've never played an order switcher live, not sure if it's something useful for a part of a song.
BricksnBeatles
Just three jumpers, right?
Isn't a 1590xx about the same size as a 125bb?
jessenator
#41
Quote from: jimilee on February 05, 2024, 08:04:03 PM
A bit bigger in width and length, but not quite as tall. The 1590BBS is the 1:1 for the 125BB on this collection.
Quote from: jessenator on February 05, 2024, 04:55:00 PM
6x11mm caps in blue
I don't think any of the projects have that configuration for electrolytic caps so I don't think that will be a big problem. The space around the 9v connection is usually pretty clear. But, I'll check again with the upcoming releases and also keep that in mind for all the future ones.
Aentons
#43
Just curious if there is any reasoning behind designing the standard series exclusively for the 1590b rather than both it and 125b? Some folks seem a tad hung up on top jacks.
Quote from: Aentons on February 09, 2024, 01:41:06 AM
A number of the circuits I'm working on for the series simply won't fit in both configurations. Some would, for sure. But then they wouldn't be "standardized" for one pre-defined hardware layout. I've got a pretty big hunch that when folks start building some of these projects they'll find them easy and enjoyable. At least, I hope so because I put in a tremendous amount of thought and planning into them, haha.
