Vox wah vero
Started by jimilee, March 27, 2016, 01:47:49 PM
aiaosu
I have this Skreddy Screwdriver clone that I'm not using much anymore. I'd love to trade this with someone for a quality Phase 90 (could be MXR or clone).
Let me know what you've got.
Sent from my LM-V405 using Tapatalk
aiaosu
Looking for a Harbinger One PCB if anyone has one. Would be shipped to Oklahoma.
aiaosu
aiaosu
aiaosu
aiaosu
mcallisterra
A recently got a friend of mine into building, and he purchased a Woodstork and Mimik to get started with. Somehow we missed out the 15n caps for the Mimik on the parts order, but I have a handful of 10n caps; would these work for C5, C12, and C15 in the Mimik, or does he need to put in a new order for the 15n caps?
Thanks!
Sent from my BND-L24 using Tapatalk
mcallisterra
Thanks!
mcallisterra
I built a Doombutter (Mid-Fi Clarinot) a few years back but didn't really put any effort into the enclosure. I found it tough remembering what the controls did without labels so I sold it and decided to build another with an etched enclosure this time. Both times I used Haberdasher's awesome etch of the Doombutter (thanks Keefe!).
I went with a worn-out looking etch to match the vibe of the circuit.
Such a fun circuit, and very musical and usable at the less-than-crazy settings!
McPilot
This was my first pedal build. Luckily, a friend has many builds under his belt and helped me out a bunch.  We decided to put this in a 125B enclosure, to make the final assembly easier. Built per the plans, this pedal rips!
When buying parts, I had to settle for the lower tolerance (cheap) resistors. It immediately was dubbed "El Cheapo" and then quickly took on a Three Amigos theme. Etching went well enough for my first time, and resulted in a good worn look, perfect for El Cheapo.
Sent from my moto g(6) using Tapatalk
McPilot
McPilot
CurlyMo
Hello,
Finished wiring up my Multiplex with Mod board and found that I get only one echo repeat across the entire sweep of the repeat knob until it goes instantly into full modulation at the very end of the range.
I do get a different delay sound between each mode (delay 1 and 2 on RE201 and Binson mode, just the one delay on Echoplex), pretty sure I'm getting the full delay time sweep on both delay knobs, mix control works, and the modulation works fine.
IC1
4.12
4.13
4.11
0
4.10
4.13
4.12
8.26
IC2
5.09
2.54
0
0
3.04
2.54
.19
.68
2.54
2.54
2.54
2.54
2.54
2.54
2.55
2.55
IC3
5.09
2.54
0
0
2.94
2.54
.23
.70
2.55
2.55
2.55
2.55
2.55
2.54
2.54
2.55
Tried running through all the solder points but nothing is sticking out to my untrained eye. Is there a specific are on the board where I need to be concentrating my efforts?
Thank you,
Curtis
Sent from my SM-G960U using Tapatalk
CurlyMo
Hello,
IC1
4.12
4.13
4.11
0
4.10
4.13
4.12
8.26
IC2
5.09
2.54
0
0
3.04
2.54
.19
.68
2.54
2.54
2.54
2.54
2.54
2.54
2.55
2.55
IC3
5.09
2.54
0
0
2.94
2.54
.23
.70
2.55
2.55
2.55
2.55
2.55
2.54
2.54
2.55
Thank you,
Curtis
CurlyMo
Hello,
IC1
4.12
4.13
4.11
0
4.10
4.13
4.12
8.26
IC2
5.09
2.54
0
0
3.04
2.54
.19
.68
2.54
2.54
2.54
2.54
2.54
2.54
2.55
2.55
IC3
5.09
2.54
0
0
2.94
2.54
.23
.70
2.55
2.55
2.55
2.55
2.55
2.54
2.54
2.55
Thank you,
Curtis
