Harbinger One 2015 not working (LFO)
Started by Kardnez, March 14, 2025, 03:57:33 PM
Kardnez
Hello,
I've finished building my Harbinger One (2015), but it doesn't work. The bulb glows continuously but quite dimly, and can only be adjusted with the Gain control. The Offset control has no effect on the bulb. The operating voltage is 18V. There's no signal coming from the circuit either, only in true bypass mode. I've checked the components without success and searched the board for solder bridges and cold solder joints. The Speed ��Pot is connected correctly. I've measured transistors Q11 and Q12, as well as capacitors C23, C24, and C25. When turned on, LED 1 flashes once.
The LFO isn't working, but as I said, there's no signal coming from the circuit either.
What could be the problem?
Thank you very much
Holger
Kardnez
Update:
I replaced Q11 and Q12 with 2N3904 transistors, and the LFO is now working. However, there is still no signal coming out of the circuit. The input signal is present at the base of Q1, but no signal is coming out of the collector/emitter. Q1 was also replaced with a 2N3904. The DC voltages in the preamplifier stage look good.
Does anyone have an idea?
Thx
Holger
NorthCoast
Can you post some pics?
What voltages are you getting on Q1?
"People discuss my art and pretend to understand as if it were necessary to understand..." - Claude Monet
Kardnez
Hi,
here are the voltages.
Q1
C 2V
B 1,32V
E 1,28V
Q2
C 5,42V
B 2V
E 1,45V
Q3
C 12,36V
B 5,42
E 4,84V
I use a 18V power supply.
Holger
NorthCoast
Hi Holger,
You mentioned you've replaced 3 transistors, what transistors did you have in there before?
Is it possible Q2 and Q3 need to be replaced?
It seems like every time you replace a transistor, there is an improvement.
Kardnez
Hello,
originally, Q2-Q13 were 2N5088 and Q1 was 2N5089. The LFO wasn't working, so I found a suggestion in older posts here on the forum to replace Q11 and Q12 with 2N3904s. This did the trick; the LFO now works. Since the input signal only goes as far as the base of Q1 and then stops, I also replaced Q1 with a 2N3904. Unfortunately, without success. I removed Q2 and tested it with a transistor tester; according to the tester, it's OK. I reinstalled it. I haven't replaced Q3 yet.
Could it be possible that several 2N5088s are faulty?
I can try replacing Q2 and Q3 with 2N3904s.
NorthCoast
Huh, I don't know.
Yeah, you could try replacing Q2 and Q3.
