Lectric-fx Flintlock Flanger issues
Started by _aj666, March 24, 2025, 06:36:16 PM
_aj666
Hey everyone, recently finished up on all my other builds and I'm coming back to this one to try and troubleshoot. I keep getting stuck at the first step where it says to test for 15 volts at the test pad. Well once I do that, I'm only pulling about 4.86 volts. Not really to sure where to go from here unless something was faulty from the get go, or I burned something up firing it up the first time. I was quite diligent when putting this one together and making sure everything was in the right spot.
Simple things can bite us in the end....
Did you double check that your voltage regulator IC/transistor (IC7) was in fact a 7815 and NOT a 7805?
_aj666
I would wish it was that easy, unfortunately after double checking it looks like its a LM78L15ACZ. So a 7815 is definitely in that spot. Not sure where to go from here.
What are your voltages on the regulator and charge pump and do you have a different one to try? If all the parts are good, in the power section, and working right, it's not possible to have 4.5v and pad 1.
_aj666
Quote from: jimilee on March 26, 2025, 01:59:48 AMWhat are your voltages on the regulator and charge pump and do you have a different one to try? If all the parts are good, in the power section, and working right, it's not possible to have 4.5v and pad 1.
I do have an extra of each, I'm noticing when I plug in the pedal to the power supply the LT1054 does get kinda hot. Can you please give me a crash course on how to check the voltages properly with this one?
Quote from: _aj666 on March 28, 2025, 08:15:21 PM
Here is an opamp pinout diagram. Power up the pedal. With the DMM on DC voltage, lace the black probe in any ground point. With the red probe, measure the voltage on each pin of your LT 1054.
Also measure each leg of your 78L15.
_aj666
Quote from: jimilee on March 28, 2025, 09:35:11 PM
Thank you for that helpful info jimilee!
My current readings on the OPAMP are as follows:
1 - 2.32
2 - 0.90
3 - 0.02
4 - 0.04
5 - 0.02
6 - 2.60
7 - 1.37
8 - 9.29
and the 78L15 reads:
Input - 7.04
Ground - 0.02
Output - 8.50
Quote from: _aj666 on March 30, 2025, 03:49:17 PM
1 - 2.32
2 - 0.90
3 - 0.02
4 - 0.04
5 - 0.02
6 - 2.60
7 - 1.37
8 - 9.29
Input - 7.04
Ground - 0.02
Output - 8.50
How confident are you the LT 1054 is in the right spot and it's good. That's where your problem is.
_aj666
Quote from: jimilee on March 30, 2025, 04:35:31 PM
1 - 2.32
2 - 0.90
3 - 0.02
4 - 0.04
5 - 0.02
6 - 2.60
7 - 1.37
8 - 9.29
Input - 7.04
Ground - 0.02
Output - 8.50
I guess I'll swap that out then, I thought I had an extra on hand. But unfortunately I don't. I'm quite confident it's in the right spot. I know IC11 is hard to see down there in the bottom right hand corner of my picture. I'll pick another up and see what happens after that. Hopefully I just have a faulty IC and it's nothing else. Made sure I had no bridged spots either.
_aj666
Well I just swapped the LT1054, but I'm coming back with the same issues. Every time I plug it up to the one spot adapter, the IC just heats up. I have one more, but I'm beginning to think the IC isn't the problem at this point.
thomasha
Make sure that the circuitry around the voltage booster IC is correct.
Measure the voltage without the 78L15, this way you can isolate the audio circuit from the voltage booster.
- Are you sure the IC was soldered in the correct orientation?
- Are you sure that the IC is good and is indeed a LT1054?
Other than cold joints, possible problems can be bad or shorted capacitors around the IC
I'm not able to see how you have the diodes around the LT1054 in the picture, but I would check the orientation of those while you're at it.
