Big Muff 2
Started by LaceSensor, December 14, 2025, 11:15:35 AM
Quote from: jessenator on December 20, 2025, 05:41:25 AMBrian, do you charge the layer colors to get them more pleasantly dark?
Yes, I have the most used layers set to custom colors to make everything easy on my eyes. I can share the settings if you want.
jessenator
Quote from: madbean on December 21, 2025, 11:10:47 PM
That would be great! Thanks.
Now if only the rest of the UI had a dark mode.
"All you need is fuzz"   ~not Lennon
jessenator
Having some fun.
This one's gonna be laser etched, with the soot in place and sealed for the black. I'll upload the art of anyone wants it.
You cannot view this attachment.
I love it! Upload it, if you have time, please.
jessenator
#19
Quote from: jimilee on December 22, 2025, 02:33:12 PMI love it! Upload it, if you have time, please.
enjoy!
This is mapped to Bean's Standard Series 1590B, with control text spacing for 13mm and 19mm knobs. But feel free to give it a check.
edit: I should mention that it doesn't have any drill markers or labels for any potential tone bypass controls
Quote from: jessenator on December 22, 2025, 05:13:40 PM
enjoy!
Thank you sir.
jessenator
Quote from: jessenator on December 21, 2025, 11:28:59 PMThat would be great! Thanks.
This will change your colors for both schematic and layout to the ones I use. The difference is my colors are much more muted in both to reduce eye strain. Only the most used layers have color changes so you can modify the rest as you like. Please be sure to back any important pref files before making this change and I don't take any responsibility for changes you make. That said, it's straight forward. This is for 7.7. I've attached a zip of the SCR I use if you wanna skip all that stuff.
DO NOT PASTE THIS IN THE delauftcolors.scr - create a separate one.
  • Copy the text below into a text file and save it.
  • Name the file something like "MyCustomColors"
  • Rename the file extension from .txt to .scr.
  • Place the file in your Eagle SCR folder
  • Open the Layout app then open the file you created using the SCR button
  • In the Options menu set Layout Background to use the Colored option and Schematic Background to Black option.
  • If you don't like the colors, you can revert back to the default by running the defaultcolors.scr
set palette black;
set palette  0 0xFF000000;
set palette  1 0xB43232C8;
set palette  2 0xB41A6B1A;
set palette  3 0xB432C8C8;
set palette  4 0xFF812020;
set palette  5 0xB4C832C8;
set palette  6 0xB4C8C832;
set palette  7 0xB4C8C8C8;
set palette  8 0x643D3D3D;
set palette  9 0xB40000FF;
set palette 10 0xB400FF00;
set palette 11 0xB400FFFF;
set palette 12 0xB4FF0000;
set palette 13 0xB4FF00FF;
set palette 14 0xB4FFFF00;
set palette 15 0xB4FFFFFF;
set palette 16 0xC8CC6600;
set palette 17 0xC8CC9900;
set palette 18 0xC8336600;
set palette 19 0xC8666633;
set palette 20 0xC8669966;
set palette 21 0xC8336666;
set palette 22 0xC8009966;
set palette 23 0xC8006699;
set palette 24 0xC8FF9900;
set palette 25 0xC8FFCC33;
set palette 26 0xC8669900;
set palette 27 0xC8999966;
set palette 28 0xC899CC99;
set palette 29 0xC8669999;
set palette 30 0xC833CC99;
set palette 31 0xC80099CC;
set palette 32 0xC8996699;
set palette 33 0xC8CC9999;
set palette 34 0xC8CC6666;
set palette 35 0xC8660033;
set palette 36 0xC8663366;
set palette 37 0xC8996666;
set palette 38 0xC8336699;
set palette 39 0xC8339999;
set palette 40 0xC8CC99CC;
set palette 41 0xC8FFCCCC;
set palette 42 0xC8FF9999;
set palette 43 0xC8990033;
set palette 44 0xC8996699;
set palette 45 0xC8CC9999;
set palette 46 0xC86699CC;
set palette 47 0xC866CCCC;
set palette 48 0xC8FBAF5D;
set palette 49 0xC8AFD134;
set palette 50 0xC86A6A6A;
set palette 51 0xC87E7E7E;
set palette 52 0xC87E7E7E;
set palette 53 0xC8969696;
set palette 54 0xC8969696;
set palette 55 0xC8969696;
set palette 56 0xC8FDC689;
set palette 57 0xC8D9FF3D;
set palette 58 0xC8E3E3E3;
set palette 59 0xC8D62525;
set palette 60 0xC839D437;
set palette 61 0xC8E6E600;
set palette 62 0xC82C7BCE;
set palette 63 0xC89526DE;
set palette white;
set palette  1 0xB4000080;
set palette  2 0xB4008000;
set palette  3 0xB4008080;
set palette  4 0xB4800000;
set palette  5 0xB4800080;
set palette  6 0xB4808000;
set palette  7 0xB4505050;
set palette  8 0xB4C0C0C0;
set palette 15 0xB4000000;
set palette colored;
set palette  1 0xC8253647;
set palette  2 0xB4847145;
set palette  4 0xC8552C2C;
set palette  6 0x64FF0000;
set palette  7 0xB4B4B4B4;
set palette  8 0x784B4B4B;
set palette  9 0xC84B6E91;
set palette 10 0xB4AF955B;
set palette 12 0xC8984E4E;
set palette 15 0xB4B4B4B4;
I placed a JLC order the other day and stupidly forgot to order even just 5 of my Muff2 layout. Sheesh.
jessenator
#24
Quote from: madbean on Today at 05:17:25 PMI placed a JLC order the other day and stupidly forgot to order even just 5 of my Muff2 layout. Sheesh.
I'll hook you up: power-IO, main, relay. Although I stuck with the slow boat, so it'll be a minute.
Although, it is val, so maybe too advanced :P
