The secret M117 flanger
Started by lars, December 18, 2025, 09:47:47 PM
There are so many versions of the MXR M117, it's not surprising there is one version that has pretty much flown under the radar for the last couple decades. Yes, there are people who know the version I'm talking about, but for the most part, it's still kind of a sleeper. Clear back in 1996, MXR made it's first reissue of the M117. There doesn't seem to be much information about that first reissue on the Internet. It appears they may have only been made for about 2 years. The majority of online demos for the M117 are of the originals or the "newer" reissues. A gut shot is nearly impossible to find of the 1996 version.
The '96 version was US-made and used good-ol through-hole components and a very interesting choice for the BBD:  not one, but two MN3004's! In the world of flangers, that makes it much more rare than the SAD1024-based M117's. I don't think there is another flanger in existence that uses two MN3004's. This version also has two independent clock circuits as well, so it's easily the most complex version of the M117 MXR has ever made. A schematic would be awesome to check out, but is impossible to find.
So how do you spot one of these "post-vintage, yet vintage" versions? The easiest way is if there is a picture of the bottom plate. MXR didn't provide any battery power option in '96, so no battery doors.
If there isn't a picture of the bottom though, you can spot them by the paint. The first reissues were always a matte rough-finish gray color with no metal flake. So if it has metal flake charcoal paint, it's not the one.
The other odd identifying mark is the LED. On the '96 versions, the LED is one of the strangest colors of red I've ever seen for an LED. It's like watermelon Kool-Aid red when it's off. You can easily see the color difference when compared with the 2004-present versions.
So here are the pics:
The insides of these rarely see the light of day...
Dual MN3004's are under them pots...
Why did I bother posting any of this? I've still seen this rare version listed as "2004-present", and it generally get's lumped in with the newer ones that just aren't quite the same. So keep an eye out! You can still pick these up for pretty cheap considering how nice they are and how rare the BBDs are. You will never regret getting a hold of one of these early reissues. Highly recommended.
Happy hunting!
Signatures are displayed at the bottom of each post or personal message. BBCode and smileys may be used in your signature.
Very cool, thank you.
Wow, this is pretty cool.  I've always thought the SAD versions were easily the best but over the years I have my doubts as it was completely new back then and I've probably heard 50 flangers since then and have probably built 10.  Plus my old-ass ears aren't likely as prime as my 17yr old version was.
So what's the gist of this circuit?  Two delays running in parallel hoping for differences in components (piggy backed)?
Quote from: gordo on December 18, 2025, 11:52:41 PMSo what's the gist of this circuit?  Two delays running in parallel hoping for differences in components (piggy backed)?
Without a schematic it's difficult to know what configuration they're running. It's odd that newer versions of the M117 look like they use a single MN3204. For whatever reason, they've never gone the MN3007 route, despite the fact the originals were running serial configuration and MN3007s are readily available. I guess BBDs are more than just stages and clock speed. There's something else going on that affects the final output.
This topic has already become "famous". If you do searches for anything having to do with a 1996 MXR M117 flanger on Google, the AI machine has already lifted several key pieces of information directly from my post, in some cases word for word. It's happened! As individuals we now have the ability to control the information shared with the entire world on various subjects. Maybe in the near future AI will tell us that 2+2 = 5. If enough blogs were to convincingly promote it, then it will happen!
"When you control the mail, you control...information!"
                                      ~ Newman
jessenator
Print is not dead. The internet dies with another bubble.
"All you need is fuzz"   ~not Lennon
museums
I scooped one because of this thread and it sounds great. I haven't compared to the earlier version but I was a little surprised to see the MXR doesn't use the multiplex configuration found in most other pedals that started with an SAD1024. Would be interesting to tap the output off the first MN3004 as an alternate sound.
Quote from: museums on January 07, 2026, 10:31:43 PMI scooped one because of this thread and it sounds great.
Glad you were able to find one! It really is a great-sounding "all around" modulation effect. I would say it leans more towards the chorus side of things. But, if we could find a schematic I could see this version being an incredible modification platform. With two BBD's in there, you could easily set up through-zero flanging by dedicating one to the dry signal line. By dropping down to 512 stages, it would still get some great chorus sounds, but be able to pull off some amazing flanged tones as well.
Quote from: jessenator on January 07, 2026, 02:52:46 PMPrint is not dead. The internet dies with another bubble.
The Internet actually died quite a while ago. It's nothing like a digital library anymore. Social Media runs the show.
Here is an update on the trimmer settings inside. One disappointing thing I found out about this version is that it couldn't do those great theremin-style sounds with the Regen knob maxed out. An awesome example of what I'm talking about is at the beginning of Van Halen's, Outta Love Again. In my opinion, if an M117 can't do those sounds, then the trimmers inside aren't set up correctly. By adjusting the 20K trimmer on the right a little bit more counter-clockwise, I was able to get those great oscillation sounds when the Regen knob is maxed. I also adjusted the clock speed to a faster setting to keep it from getting that awful deep/seasick rubber-band sound that so many flangers are set up to do.
Here's the pic of the trimmers:
It definitely sounds even better after the adjustments. Now the chorus has more of that "Andy Summers" sparkle.
