Grawlix — A Green Ringer with Knobs
Started by Aleph Null, June 09, 2026, 08:20:00 PM
Aleph Null
I've been exporing analog octave circuits lately and nothing sounds quite like the Green Ringer to my ears, but it generally needs help to sound its best. Grawlix is a Green Ringer with some quality-of-life features added.
I repurposed an old enclosure as the original occupant had been superseded by a newer design.
The first half of the circuit is the classic Green Ringer topology with modernized and streamlined values. The bias network is a little eccentric, but it gets the necessary voltage at the base of Q2 to maximize the headroom and octave effect. Instead of a fixed gain, Q1 can now be adjusted. This lets you set the level that hits the rectifier section for the most prominent octave. It can also be cranked up to some serious fuzz. The Texture control pans between metallic fuzz and full octave up. The further clockwise, the more prominent the octave will be. This also makes diode matching less critical, as the Texture control can be adjusted until the octave pops. Q3 buffers the output—I tried to ditch this, but the rectifier is very picky about what comes after it!
The octave section is followed by clipping diodes. These have a similar effect to placing an overdirve after a Green Ringer; they act as a crude form of compression to keep down the crazy transients the octave can produce. With the Gain control low, they don't do anything. After about half way, they start to color the signal.
Tone is a tilt EQ with a mid bump around 800Hz. Clockwise, it cuts the thump of strong transients that can be created with the Gain set low. Counterclockwise, it cuts the fizz and treble without getting too dark. In the middle, it gives you a throaty midrange, similar to running a Tube Screamer after your octave.
Last is a make-up gain stage to ensure a good amount of boost is available at all times.
This circuit definitely does the Green Ringer thing, but I think it's also a reasonable substitute for a Moonrock or a Superfuzz. It can fuzz, but it's more open and dynamic than most octave fuzzes.
Here's a demo:
As always, I have extra PCBs. If you're interested, DM me!
jessenator
"All you need is fuzz"   ~not Lennon
THAT's the tune you pick to demo it???  ;D
Aleph Null
Quote from: gordo on June 10, 2026, 11:02:05 PMTHAT's the tune you pick to demo it???  ;D
I don't know any blues licks...
Quote from: Aleph Null on June 11, 2026, 02:48:24 PM
What ever key you're in, slide up about 3 frets and bend a lot.
