Request: BL3208-based delay
Started by culturejam, March 06, 2012, 04:36:04 PM
I've got a DM-2 built up with 2x 3208s. There is a problem with it though that I have not been able to solve. The expandor portion is not operating correctly and killing the delay signal with much prejudice. So far I have not figured out why---I don't think it has anything to do with the different BBDs.
Point is, I can't intelligently comment yet on the differences between that and the v3205. I am less inclined to do a hybrid digital/analog at this point, mostly because I have at least three or four more unreleased delay ideas I'm still in the process of finalizing.
Thanks for the update. I may mess around with the hybrid thing and see what happens. I've had enough luck with extending the 2399 delay time with just heavy-haded LP filtering that I might see if I can do a 2399 + 2x 3208 but without a compander.
There's no good reason to do it, other than just for the sake of it, but I suppose that's good enough.  :)
Side note: maybe I'll just 10x sallen-key low-pass filters in series?  :D
