Mangler
Started by Sigesmundninja, March 14, 2012, 03:50:16 AM
Om_Audio
Cool! Let's hear it! Also, did you have a schem for the tranny switching mod?
C
shawnee
Man that looks great. Super clean build!
Great build.  Love the look and enclosure.
Josh
That is soooo sexy!  :o Love the look and the guts make tasty viewing 8)
slimtriggers
Very cool.  Has sort of a cold war era military device look 8)
stevenrun
Love the retro look. Looks like a panel off a 1960s nuclear reactor or something.
Sigesmundninja
I'm really glad to get all these positive response, thank you guys! Will see what I can do about a audio-demo.
Om_Audio:
this is how I wired the switching. (nevermind the orientation of the transistors, think the OC's are mirrored)
Om_Audio
Wow, thanks. So I am a n00b for the most part but-
1- Did you pick Q2 to put the trim pots on for any particular reason vs Q1?
2- Did you consider an external trim for both trannys on Q2?
I don't really understand biasing yet but I assume it is somehow an adjusting that only needs to be done on one tranny or the other.
Quote from: Sigesmundninja on March 18, 2012, 03:47:39 AM
Om_Audio:
Sigesmundninja
Not that I'm a expert on this, actually I don't understand it at all. I will let someone else answer why the bias is on Q2. The reason the pot for germanium Q2 is exterior is because germanium's are heat-sensitive, if if its cold the bias-pot is in one position and if its warmer I might turn it to another position. Silicon-transistors aren't heat-sensitive and to my ears they just sound good i "one" position, that's why the silicon-bias is internal....  I think  ;D
