Author Topic: Drill hole size for 1/4" jacks  (Read 15578 times)
« on: April 12, 2012, 08:03:53 AM »
Hi everyone,
I have a question on drill hole size for 1/4" jacks. What's an ideal size hole for most jacks out there?
The reason I'm asking is that I just got my first drilled enclosure from PPP  (for my in-progress Pork Barrel). For reasons I can't quite recall, on the drilling template I provided them, I went with 11/32" for the hole size. I think I thought that's what I was seeing on the Pork Barrel drill template. Anyway, the hole will accomodate one type of jack I have, i.e. these cool-looking ones I got from LaceSensor in his holiday PIF. Some Neutriks I have don't quite fit though.
Is 3/8" a more standard size?
Thanks,
Bret
  • Global Moderator
  • Jacob - SK, Canada
    • JMK PCBs
Re: Drill hole size for 1/4" jacks
« Reply #1 on: April 12, 2012, 08:19:41 AM »
Yes, I think I usually use 3/8".
« Reply #2 on: April 12, 2012, 01:49:06 PM »
Thanks! I appreciate the guidance as always.
bigmufffuzzwizz
  • Magic S.
    • Magic Pedals
« Reply #3 on: April 27, 2012, 06:09:39 PM »
Some parts will vary in size..3/8'' is general and all jacks should fit through. I've had some that are smaller so they won't hold tight in place..Those held really well with 11/32. So yes your right on your questions.
  • Jon P
    • Midway Fair
« Reply #4 on: April 27, 2012, 06:33:44 PM »
Standard metal jacks I use 3/8. I had to use something slightly larger for the low-profile plastic jacks that Bean suggests for the mini builds, but I can't remember what I used. It might have been 7/16.
Myself's music & things I make: http://jonpattonmusic.com. My band: http://midwayfair.org. PCBs of my designs from: http://www.1776Effects.com (Bearhug Comp & Cardinal Harmonic Trem); http://www.jmkpcbs.com (Hamlet+ delay & Blue Warbler envelope vibe); Snow Day OD/Flabulanche: www.madbeanpedals.com
DutchMF
« Reply #5 on: April 28, 2012, 11:38:34 AM »
I'll help out the metric people: 10 millimeters  ;)
Paul
  • Aotearoa
    • http://alanp.info/
« Reply #6 on: April 28, 2012, 02:28:25 PM »
Simple soul that I am, I eyeball which drill bit is closest.
The way to test it is to drill a hole in a spare bit of wood, and see if the component fits, and if the hole is too big or small.
DutchMF
« Reply #7 on: April 28, 2012, 02:41:46 PM »
I love to get these insights in how everybody has their own methods. I measure every part with a caliper micrometer.......  ::)
TNblueshawk
« Reply #8 on: May 01, 2012, 08:35:01 AM »
Ha! Usually I'm that OCD but for some reason when I first started I used the unibit and just made sure I went slow and would dry fit it as I went. Now of course I pretty well have them all memorized.
The only issue is the DC jack. That one is so easy to screw up and overdrill it...at least with the uni's I have right now.
John
  • Josh
    • 1776 effects
« Reply #9 on: May 01, 2012, 11:29:39 AM »
Measure once, drill twice.  :o
TNblueshawk
« Reply #10 on: May 01, 2012, 12:08:18 PM »
I've been on the wrong end of that too many times  ::)Let's see. There is:
- Tile cutting. Screwed up that so many times I don't even get mad
- Hardwood flooring. I have even screwed up cutting the end piece where you have the bass mold and quarter round as an "error window"
- Building a hot tub house around my hot tub.
- Any and all wood work projects
- Etc...
John
DutchMF
« Reply #11 on: May 01, 2012, 12:52:48 PM »
Word! No, double Word!!!
