Author Topic: soft touch switch for keyboardist?  (Read 1828 times)
B_of_H
  • Solder Ninja
  • electronics moran
« on: October 02, 2010, 10:28:11 AM »
anyone have any suggestions for building an effect for a keyboardist?  I specifically want to make it easier than a footswitch to turn on and off as he'll be using his hand.  I'd prefer true bypass as well.
fwiw, I think i'm going to put a fuzz (sabertooth) and aqua boy in a box for him but suggestions are appreciated.
illcom
  • Transistor Tickler
Re: soft touch switch for keyboardist?
« Reply #1 on: October 02, 2010, 10:43:39 AM »
you coulld use this ON/ON 6 pole switch for true bybass, minus the LED, but with this switch it's easy to know if the effect is on.
If you need absolutly Need a LED you can use a millenium bypass
B_of_H
  • Solder Ninja
  • electronics moran
« Reply #2 on: October 02, 2010, 10:48:23 AM »
yeah, I was looking at something like that.  I think i'd need it to be pretty big and was actually thinking of using a guitar pickup selector with the little rubber piece on it.
illcom
« Reply #3 on: October 02, 2010, 10:56:52 AM »
you could also screw that on top
B_of_H
  • Solder Ninja
  • electronics moran
« Reply #4 on: October 02, 2010, 11:01:00 AM »
nice.
now my brain is finally starting to get going.
I think I could put that switch as an on/off then use a rotary or one of these 5 way switches:
http://www.stewmac.com/shop/Electronics,_pickups/Components:_Switches_and_knobs/Super_Switch.html?tab=Instructions#details
to select between effects and combinations of effects.  Say delay, delay+tremolo, delay+fuzz+tremolo, tremolo, fuzz
i'm going to work up a diagram I think in the next week.
