Chunk Chunk 2012
Started by toolguy, July 29, 2012, 03:09:59 AM
toolguy
Hello.
I did my 1st "big" build this weekend and could use some some tweaking advice.
To my ears...the C.C. is waaaay too trebly. If I rotate the T.pot anywhere past 1/4 from zero (full counter clockwise) it just seems too harsh. Are there any tweaks for this? I had to use a 25kb (all I could get ahold of) but I don't think it's causing the issue.
Sounds great otherwise. ;D
Try socketing C15 and use a larger value there. Start with 10n and work your way up until you find what works for you.
toolguy
