Cherrybomb Gating - solved! and pre-gain?
Started by the3secondrule, September 14, 2012, 01:42:55 AM
the3secondrule
Edit: I went back and redid some fairly heinous looking solder joints and it's working fine.  ;D
also, was thinking about adding a pregain, as I need to roll back the vol on my SG to get some real clean boost happening. any thoughts on a suggested value?
hey all, I've built up a cherrybomb, and i'm getting serious gating. At high full gain i'm getting some fairly healthy fuzz, but it is not sustaining.
at lower gains it is super farty and gated, and I have to hit the strings pretty hard. i'm not getting anything resembling a clean boost.
The only sub was using bc109's for all Qs. I had previously tried pn3565 with the same results.
have double/triple checked all resistor values.
here are the voltages:
DC jack 9.2
Q1
E 0.35
B  0.92
C  1.6
Q2
E 0.96
B 2.3
C 5.42
Q3
E 1.8
B 2.5
C 1.9
any thoughts?
J
garfo
What are your reading for Q3 collector now?it should read arround 5.1 volts as well as should Q2.
