Please Help! Daughter Boards
Started by jalmonsalmon, October 04, 2012, 11:40:22 PM
jalmonsalmon
  How do you put a daughter board into another circuit?
I want to put a klone buffer or mosfet buffer inside my Boneyard and also make it to where I can switch it off and am really scratching my head about to go about hooking it up.
My thoughts are in to daughter board, out to boneyard IN and ground everything but kind of baffled on the 9v part and getting it on a switch.
Can anyone steer me in the right direction?
THANKS!
Information is not knowledge
Knowledge is not wisdom
Wisdom is not truth
Truth is not beauty
Beauty is not love
Love is not music
Music is THE BEST . .
Wire from input jack to D.
Run a wire from C to where the input goes for your stomp switch.
Connect E & F together
B goes to the input of your buffer board
A takes the output from buffer board
Power is easy. Just connect to +9 and GND at the jack.
This will make the switch turn off and on the input buffer.
pryde
Also I just replied to your request in the mods section so look there again if needed.
jalmonsalmon
Thank you all so much!
I learn alot from everyone here everyday :D
Wisdom is not truth
Truth is not beauty
Beauty is not love
Love is not music
