I saw the light!!!
Started by GrindCustoms, October 14, 2012, 08:50:07 AM
GrindCustoms
OftenFX Daily Driver aka Mini Tube Grinder! :twisted:
Looks great as always! What's the Daily Driver sound like? I'm not familiar with that one.
GrindCustoms
It's basicaly a fully modded tube screamer in a layout designed for 1590A use, OftenFX is Saxonthefest at BYOC.
So you can litteraly build any tube screamer with this layout aswell, doing the Si/Lifted/LED clipping switch mod is already on the pcb.
Kudos to Matt for this awesome layout  8)
slimtriggers
Man, you even got stacked ICs in there!  Very cool 8)
wolfingsworth
Man there's a lot going on there! nice work!
GrindCustoms
Quote from: slimtriggers on October 14, 2012, 01:27:50 PM
Thanks, this stack is a 4558D on a 4580D, there's just something about the mids it gives that i like a lot.
Quote from: wolfingsworth on October 15, 2012, 04:18:33 AM
Cheers!
I think this is the TS that i built to date that pleases my ear the most, i do not use these overdrive as an overdrive, with the gain all down.
But this time around, with the lifted option, the gain control now have a use, it just boosts even more, the LED mode is pretty similar to the Lifted, i choose LED that had a really high fvd, so you have to hit really hard to have them clipping, wich is cool because i have a heavy picking hand.
It also have a W20K tone pot and MPSA18 instead of 2N7000, tone cap values have also so been played a bit to retain low end in the affected sound, wich is a lack for me on stock TS. When i play a pinched harmonic on the low B string i like to hear is overtones.
