The text is basically a repost of what I put at BYOC. Sorry for the laziness, but I would've basically written the same thing anyway.
A while back, I decided that it would be cool to have a 2 in 1 pedal that had CJ's wonderful Shoot the Moon with Rick's cool Little Angel Chorus.
I threw together a PCB that was itself a 2 in 1. The top side is the Little Angel Birthday Edition. The bottom side is the Shoot the Moon Trem. Build one, build the other, or build both. Lots of options. It's all SMT except the LED/LDR.
I designed the PCB so that it would fit in a 1590A. I knew that it would be a bit of a challenge stuffing it all in. Turns out I was right. While putting this together, it was even more challenging than I thought. I had to use more wire than I had planned, because some lengths had to be longer to accomodate them being stuffed in in a certain order. But what really made it difficult was the 3PDT toggle. The toggle sits on top of two 9mm pots, so I mounted it as low as possible and it still brought the board up higher than I'd like. But (after many hours) I was able to wire everything up, and it is a 2-in-1 pedal where both the Chorus and Trem are true bypass, you just have to use the 3PDT toggle for the Chorus.
Here it is from another angle so that you can see the control labels.
And of course, the guts. No shot of the underside, but I can take the next board I populate if people are interested.
