L-Pad Attenuator
Started by sirbergersworth, January 08, 2013, 06:54:13 PM
sirbergersworth
I built this L-Pad attenuator yesterday. $15 8ohm/100watt L-Pad, a few $2 switches, jacks, couple of caps, wire from a broken computer power supply and a $5 aluminum enclosure.
I installed a true bypass switch on-off-on bright switch with a 4.7uf cap on one side and a 10uf cap. Both non polarized caps. All 18 gauge stranded wire. I haven't drilled holes for the venting yet but from my tests with my amps I will not need a fan. I wouldn't use this with anything over 15-20 watts.
I haven't decided on a paint job or decals yet. Any ideas?
I plan to use this with my vht special 6 head for very quiet bedroom levels (kids right above sleeping)
Tested last night and today and it works good. Worked just as well with a tweaker15 to be able to hit its sweet spot and not irritate the neighbors.
With the s6 it was very nice. I will be able to practice with a real amp instead of sims (don't own amp with headphone out)
Thanks for allowing me to brag.
Rob
"Comes a time when the blind man takes your hand, says, "Don't you see?"
-Robert Hunter
Guitar Master
I got the same exact switches the other day! The switches look cool
stecykmi
wow very cool project, i bet a lot of people are gonna be interested in this one.
Is it your design? source on the attenuator?
sirbergersworth
Quote from: stecykmi on January 08, 2013, 09:35:41 PM.
Not my design at all. I just googled "DIY attenuator" and found this page.
http://guitarprojects.weebly.com/diy-attenuator.html
i added two different bright switch options. I guess that's a mod ;-)
Very cool, cheap and useful project.
-Robert Hunter
sirbergersworth
L-pad is here
http://www.parts-express.com/pe/showdetl.cfm?partnumber=260-262
There are other l-pads on parts express as well. Don't pay attention to wattage. These are intended to be a tweeter control after a crossover, etc.
One guy used a stereo 8ohm 100 watt and wired to switchable to 8.or 16 ohms. I can't find that link at the moment.
-Robert Hunter
The layout for Ken Fischer's Trainwreck Airbrake is floating around the internet.
Stomptown
very nice! I would love a DIY attenuator but I need 40 watts! Does anyone know how to build a Dr Z Brake Lite clone?
Ettore_M
Quote from: Stomptown on January 09, 2013, 12:18:14 AM
I think the Dr Z Brake is based on the Airbrake (the one about alanp posted above).. You'll find it on the net. A little more complicated than the L-Pad attenuator, but it's supposed to sound better...
Hector
" I would first try what I call The American Approach, which is simply this: "If X is good, then 2X simply HAS TO BE twice as good."  ;D "
- Culturejam
Nice build dude.
I would give it a nice hammertone finish.... but then I would say that wouldn't I  :D
An amp attenuator has been on my 'to do' list for ages now. Thanks for posting the links/info!
pryde
Nice build. I whipped up a simple LPAD for my 5E3 Tweed and it works great. Used a 3.3uf cap on the attenuator to retain some treble in the signal.
Haberdasher
I need something like this for my tweaker 15 head.  Thanks for the links sirbw!
FABBED PCB's FOR SALE:
Now carrying Matched JFETS
tenwatt
Try this:
http://ampgarage.com/forum/viewtopic.php?t=2402&postdays=0&postorder=asc&start=0
Not too bright....
sirbergersworth
Quote from: Haberdasher on January 09, 2013, 05:19:39 AM
It works fantastic with my tweaker 15.
Just remember that you still have to make sure you have a speaker plugged into the attenuator so you don't blow your amp transformer.
-Robert Hunter
sirbergersworth
Quote from: raulduke on January 09, 2013, 01:57:27 AM
Nice build dude.
Thanks for the complement. I think I will do hammertone copper finish with a lawyer clear coat to make it alligator like crazy. Nah, that will take 4 weeks to cure out.
-Robert Hunter
hammerheadmusicman
This looks good man! I recently built a DrZ AirBrake for my Maz18, best decision ever, great live to give you more power tube saturation at lower volumes, and the bedroom playing too!
George
I play Guitar, and Build Stuff..
