Author Topic: Volume pot issue  (Read 1741 times)
Bman40
  • Diode Destroyer
Volume pot issue
« on: January 10, 2013, 03:03:43 PM »
Hey all - I just finished a Mudbunny build - my third project to date (Thnderpuss and a GGG Fuzz Face also complete).
I had HUGE trouble with the crap wire I used breaking at the PCB when tried to install it... very stressful.
I have a weird issue wth the volume pot. I was super careful not to let the pot get too hot - I cooked one once in trying to make a perfboard fuzz - but when I test the cicuit it works, when I get it all in the enclosure it works, but when I tighten the bolt on the pot to the enclosure - the volume kicks out.
i think its shorting somewhere, somehow - is it when the top of the metal pot / solder tabs touch the enclsoure? If i wrap the whole thing up in electrical tape (kidding - but if I try and insulate the top of teh box with tape or the pot itelf)
If I leave the pot in 'loose' (not tight to the box) it works....
Any thoughts?
thanks
Barry
  • Jimi Lee
Re: Volume pot issue
« Reply #1 on: January 10, 2013, 03:49:56 PM »
I do put electrical tape on the tops of mine to keep it from shorting out. I had the same issue once.
GermanCdn
  • Curtis - Calgary, AB
« Reply #2 on: January 10, 2013, 05:29:51 PM »
I use 3M double sided foam tape, but leave the cover on the one side.  Prevents shorts and gives a little cushion.  Or pot condoms.
Bman40
  • Diode Destroyer
« Reply #3 on: January 10, 2013, 11:05:08 PM »
Thanks guys
