Holiday PIF Fuzz and Dr. Boogie
Started by jprizz, March 09, 2013, 05:34:06 AM
jprizz
I was fortunate enough to be the lucky recipient of a pair of transistors as part of the holiday PIF goodness from JakeFuzz (Paul). Long story short: I stumbled into pedal building accidentally. I am not a fuzz pedal user to begin with but for whatever reason when I found out you can do DIY pedals I wanted to try and clone a Hartman GE fuzz pedal. So here is my attempt.
Paul paired up a Mullard era General Electric (the British GE not the American one) GET113 in Q1 and a goldpin HEC 2N404 in Q2 to get me to that Hartman tone. The only modifications I made was to add the pre-gain mod and socket C3 for easy tweaking. I shamelessly copied the Hartman look too. Enclosure is Hammond 1590D finished in transparent copper from PPP. This finish MUST be done on a Hammond enclosure! My knock-off enclosure in this finish can not even compare.
This is my first fuzz so I'm not sure what, if anything I need to tweak. Time and playing will tell. A big THANK YOU goes out to Paul for his holiday spirit!
-Josh
jprizz
jprizz
Dr. Boogie: straight forward here. Friend made the white vinyl sticker for me. Sounds mean.
jprizz
fish22
sweet!
I LOVE the Dr. Boogie. The decal and matte black look great IMO!
I really need to build one of those.
Hi, my name is Wyatt.
wolfingsworth
Top notch! The wiring in the fuzz is outstanding!
Excellent work.
Hartman's Ge fuzz is what led me to want a Fuzz Face on my board. My local guitar center had one for $90. I went home to think about it overnight and it was gone the next day. :(
I got a red dot NTK275 Hartman Fuzz...
So awesome.
zapme
JakeFuzz
Yes! I am glad to see these in a build! There are few better transistors for Q1 than that GET113, it is really smooth and dark. One tweak I have been playing around with is to vary the value of the 470R resistor; I think Mike Fuller did it with his 70's fuzz and called it mids. It adds a sort of weird boominess and midrange of course but it makes it sound fatter. Excellent wiring!
jprizz
Hey Paul, I just hope I can do your transistors justice! How much are you varying from the 470R?
QuoteExcellent wiring!
Thanks! I feel like it looks too cluttered up with the extra wiring from the RoadRage, at least not as simple as a FF should look.
ch1naski
Did you build it from the schematic, or is there a layout floating around...
one louder.
JakeFuzz
I usually use a 47R lower limiter and a 1K trimmer. I think it is a 1K in the 70's too but I don't really remember.
tiagojoy
