Voxy Brown build done (no pics)
Started by Bucksears, April 21, 2013, 12:16:39 PM
Bucksears
Just finished the Voxy Brown external - i.e. not in a case yet. I had high hopes for this one, and it does sound good for the most part; it's just that it's too 'cocked-wah' for me when the boost is on. This is probably a testament to it's intent - to really nail that Brian May (or Mick Ronson a la 'Ziggy Stardust') lead tone. With the boost on, it really reminds me of the classic Runoffgroove 'May Queen' circuit, but with an EQ and gain control. If that's what you're looking for, the Galileo/Voxy Brown is the one to build. I built a May Queen about 5 or 6 years ago and didn't really like the sound all that much.
The non-boosted mode is ok, but I think I like my AC-Tone clone better overall for both low/med/high gain Vox-like tones. I'll have to play around with it a bit more before deciding whether or not to box it up.
Just my $.02
I've hardly been using the boost much lately myself. It does nail 'that sound' when you use it, though.
I've got quite a few mods in mind for a new iteration, like:
Mosfet polarity protection
Lower-noise biasing method
Tinkering with the tone stack for more bass (I leave the bass knob on 11) - maybe see what a Bax does
Flatter freq boost, but add a toggle for the extra treble
idgit
the boost was the problem I had with the original Galileo.  It was an icepick, and although the gain was very useable and the tone was rich enough with my amp, I convinced myself I had to sell based on the boost.  so glad to have found the Voxy because I missed the CB30 side very much.  more bass would be a great mod, as well as a mod to allow low gain, too.
BAX is also a great idea.  The Gal really did have a nice gain, glad to have the chance to build something similar
ch1naski
#3
Reviving an old thread.....jubal81, any word on ideas for the tone section yet? I've got my board put together (finally), and while it does do queen sounds pretty spot-on, I think the treble side of the stack could use a little taming for my setup.
The boost section, I think, is good for my setup. Nice.
Sent from my SPH-L710 using Tapatalk 4
one louder.
Quote from: ch1naski on September 24, 2013, 07:04:15 AM
I've been thinking about doing the AC30 sound with a completely different topology. Might have something to show early next year. The mu-amp setup makes it really easy when it comes to sourcing JFETs and getting a good sound, but I don't think it has as good a response - kinda stiff feel to me.
I think I've mentioned it before, but I keep the bass control all the way up and back off the treble to beef up the sound.
I ended up taking mine off the board and stripped a few parts for other builds. With my Fender Twin Reverb it was just to piercing and I could not get the sound I wanted out of it. It did sound 70% better on my Bassman 135 but still not the sound I was after. So I guess it was just not meant to be. I gave my 2nd PCB to Timbo and I hope he has a better experience than I had. I too have high hopes for this pedal since I love the AC sound.
fendman
I still use my Voxy Brown...more than I did when I first built it. I have it after the Faultline and it sounds good I don't use the boost that often.
Mike
ch1naski
Oddly enough, the boost is my favorite part so far....but I have yet to box it and really play with it so that may change
one louder.
Just thought of something. On the build doc, some of the values are in uF and could be confused for nF. It's trebly for sure, but crazy trebly could be a cap goof.
ch1naski
If you're referring to the .68uF , I got that one. The "....... .68" almost threw me off :)
one louder.
ch1naski
I realized what my issue could be. I'm testing it through a Maz 18, which is basically a souped up vox. The distortion side doesn't mix well with it.  Same if you play it through a vox amp, I've heard. I didn't bother trying the boost, I'm sure that will sound fine through it.
Guess I better wrangle my Tone King away from my son to do the testing.
one louder.
idgit
Quote from: jubal81 on September 24, 2013, 04:11:38 PM
Old thread revival because I'm getting to building this.......
I had the Catalinbread V1 and sold it because it was so piercing when boost was engaged.  It was out of control harsh.  The main reason I want to build this pedal is for the non boost side, but also maybe find a way to tame the treble boost....
Howdy!
Here's the schematic. The circuit on top is the main circuit and the one below is the treble boost. On the top one, try putting C7 on a switch with a larger capacitor, maybe 4.7n to 22n to add some lower end back to the circuit.
For the boost, you'll want to raise the values on C19 and C21. Try 47n for C19, 22n for C21 and 220K for R20.
