C500k pot same as B500k
Started by octa805, May 06, 2013, 04:44:18 AM
octa805
Just backwards?
Is that really all there is to it?
No. A C500k is like a backwards A500K pot. B is linear, which has no curve, whereas C and A are logarithmic and have a curve.
Stomptown
Here is some pretty good info on pots. There is a graph if you scroll down that shows linear/log/reverse (anti)log and how they behave as you turn them clockwise.
Quote from: Stomptown on May 06, 2013, 08:36:22 AM
I think this was the intended link:
http://www.geofex.com/article_folders/potsecrets/potscret.htm
octa805
Hey, thanks
I actually meant A500 and C500 since they share the same curve just inverse.
Simply put, I want to use an A500 for the effdub distortion that calls for a C500
Thanks again. Ill go read now!
Stomptown
Quote from: midwayfair on May 06, 2013, 01:05:28 PM
Oops! I guess I shouldn't try to answer questions at 1AM!  ;D
