Mandroid Corrections 7.26
Started by madbean, July 26, 2017, 11:46:48 PM
I made a few updates on the Mandroid doc -
- Modified the drill template. I changed this because when I made it I forgot to take a measurement on one of the momentary pushbutton switches I linked in the doc. So, I had to move the drill spot for that (pos1). Also, I moved the DC JACK to the side because I think it will make it much easier to build...esp. if you do not use the Lumberg style slim jacks.
- Added a note about offsetting PCB mounted pots due to the height of the Alpha rotary switch
- Corrected the image showing where to put the ring tab on the rotary switch (as in now it shows the correct place!)
- A couple minor corrections on the voltages chart.
Please download the newest versions of the doc and drill template and use those instead.
http://www.madbeanpedals.com/projects/Mandroid/Mandroid.pdf
http://www.madbeanpedals.com/projects/Mandroid/Mandroid_DRILL.zip
It looks like I transposed the voltages on the two sides of the HT8950. I'll get those corrected and updated later today.
