Octave LB
Started by wgc, September 27, 2014, 09:27:44 PM
chuckbuick
Nice work, Billy.  I'm looking forward to seeing how this develops for you.  The swirl is sweet, too.
Can you mount that connector, or get a panel mount version, so that you could use it with boards that are not specifically designed for that connector?
Quote from: pickdropper on September 29, 2014, 08:21:55 PM
This is very cool, Billy.  The pedal reminds me a bit of the Henrietta Engineering pedals, although theirs have standard jacks, so this is cool in different ways.
I too like the idea of the modular connector.  A cool next step might be to come up with a standard wiring harness for a Pedaltrain Nano or Mini so that it looks really neat and orderly.
A Lemo or Hirose connector would work well, but it would likely cost more than the entire pedal. How about a panel mount USB connector?  Neutrik makes some for about $5.
Thanks guys!
Dave,
I'll have to check out the he pedals, haven't seen them.
A harness is in the works and is the actual intent. I have other ideas that this could support too, but one step at a time. ;)
I have thought about USB but I really want something that locks or at least has a positive snap.
Quote from: chuckbuick on September 30, 2014, 12:08:34 AM
Thanks Mark! There's a whole series of these connectors,  it could be pigtailed if you wanted to use without a pcb made for it. I'm just scratching the surface of what I think could happen, though some of it is probably a bit involved for me at the moment.
Edit: realized I didn't answer your question
I think they do have a panel mount version but might be something not 2x2. I'll check and let you know.
Just checked, there are panel mount versions, but they protrude a bit so the mating connector can snap into place.
I might explore using the single row 1x4 style since it might be easier to create the opening in the box.
