Projects => General Questions => Topic started by: ferdinandstrat on March 24, 2020, 02:42:30 PM
Title: More depth out of the Wavelord
Post by: ferdinandstrat on March 24, 2020, 02:42:30 PM
So I find myself having to max out the depth, on the sine and triangle waveforms anyway, the square sounds great though. I can barely hear the depth especially on medium to high speeds(I know that on high speed it's supposed to sound like a ring mod)
I am using the NSL32 instead of the VTL5C9
Title: Re: More depth out of the Wavelord
Post by: madbean on March 24, 2020, 02:57:07 PM
What optocoupler did you use?
The only tweak available to increase depth would be to lower R24. It's 1k stock but you could go down to 470R. This will increase the max brightness of the internal LED which in turn will increase the range from dark to light in the internal LDR.
Post by: ferdinandstrat on March 24, 2020, 03:01:50 PM
NSL32 but I dont think it was the R3
And I figured as much, but for some reason I thought about increasing the value...no idea why
Thanks, Madbean!
Post by: ferdinandstrat on March 26, 2020, 06:15:47 AM
I replaced the 1k with a 470R and there's no noticeable difference.
Post by: ferdinandstrat on March 28, 2020, 07:09:58 PM
I checked and I dont think it's the R3 version of the NSL32
Post by: madbean on March 28, 2020, 07:54:12 PM
Quote from: ferdinandstrat on March 28, 2020, 07:09:58 PM
All the R3 I have have R3 printed on it. If that's the case it could certainly explain your issue. The off resistance of the R3 is 10 times that of the R1.
Post by: ferdinandstrat on April 24, 2020, 06:42:54 AM
NSL32R3 or NSL32SR3? Cos I just got the SR3 and no change
I also noticed that on the sine wave the indication led doesnt turn off completely unlike on the triangle or square wave
Post by: ferdinandstrat on April 25, 2020, 04:28:54 PM
Due to the oddities with the sine wave not turning fully off and another issue with the multiplier having an additional 1/4 division after the highest one I tried replacing the lfo chip which didnt change anything either
Post by: madbean on May 13, 2020, 12:47:43 AM
Quote from: ferdinandstrat on April 25, 2020, 04:28:54 PM
I went back an looked at the Datasheet for the TAPLFO3 and it turns out there is a reason for the setting beyond 4:1 on the multiplier. It's not shown on the application circuit but it is documented as to why that happens...I just did not put it together until I re-read it.
I will post a mod tomorrow to show how you can eliminate that extra setting. It should be very easy to do.
Post by: ferdinandstrat on May 18, 2020, 12:13:00 PM
Thanks man, you are awesome
Also, I got a VTL5C9 and it sounds much better, there's a lot more depth
Post by: madbean on May 20, 2020, 01:08:09 AM
Quote from: ferdinandstrat on May 18, 2020, 12:13:00 PM
Okay, that's good to hear. I didn't want to suggest that since you already replaced the initial opto but I do agree that the c9 does work much better for the TAPLFO. I noticed it much more on the second bank of waveforms (b/w the NSL and 5C9) but overall I think the fast response time of the C9 works out to be a big advantage.
I'm a little late getting to this but I will do my best to get the multiplier mod done tomorrow.
Post by: ferdinandstrat on May 21, 2020, 03:50:17 AM
Its all cool man, you already helped me a lot here
Post by: madbean on May 25, 2020, 01:40:10 AM
Okay, finally posted the Multiplier fix here: https://www.madbeanpedals.com/forum/index.php?topic=31324.0
Post by: ferdinandstrat on May 25, 2020, 06:25:44 AM
Brian, did I ever tell you that I love you?
