Finally finished my pedal power supply project. It has 8 x 9vDC outputs (2amps) for all my regular stomps and a 20vAC output (1amp) for my Blackstar pedal.
Originally it didn't work even though the rocker was lighting up, so I put it aside and came back to it today after searching the web and finding that I'd wired the rocker wrong (the lamp lights off the 3rd prong, the rest of the circuit goes off the center lug - I'd wired everything off the 3rd lug).
Anyway, it looks like crap now after having put it away for 3 months or so (paint was too soft), and the jiffy enclosure is really too light for what's inside (probably 3 pounds of copper and magnets all told) and none of the jacks are flush so I will re-house it one day if I can be bothered. In the meantime it will get mounted on my pedalboard.
Regardless, behold, the S.L.O.P.P.Y!
Great name.. looks like that was a fun build. I have yet to make a power supply.. one day.. one day.
What size is the enclosure?
Cool build. Looks like you can do some welding with that rig!
That's a great build man... I especially love the name! 8)
Don't feel too bad, I've seen plenty bigger, yours is still verypedalboard friendly!
The size is fine, but ultimately determined by the two big arsed trannys in there. It's probably a little wider than 2 boss pedals side by side, and a bit higher. I'd like to make a cleaner enclosure though...
So it's a 125bb enclosure?
No, it's a plastic Jiffy box. I'll get the dimensions up shortly, but it was the cheapest thing in Jaycar that was tall enough for the transformer(s) (1 amp, multiple voltage taps) that I ended up using.
Bit of a funny story about why it has 3 trannys: I brought one with the intention of rrunning 20v and 12v off it at the same time and doing the current job, but for whatever reason that didnt work, so I grabbed another one to do 20v only. THEN, I found an 240v->20vAC wall wart at the local flea market that I grabbed for $7 promptly butchered open with a screwdriver and a hobby knife. At that point I figured I might as well run two regulated 9vDV circuits and have a dedicated 20vAC tranny....
Very nice! I built 2 recently myself.
Quote from: Willybomb on May 22, 2013, 02:31:30 PM
Ohhhhhh ok you said that in the post earlier, I didn't put it all togetehr, sorry about that. What's a jiffy box?
That's a cool project. 8)
This is a jiffy box, but the photo isn't great...
http://www.jaycar.com.au/productView.asp?ID=HB6012
