Why is my Op Amp smoking?
Started by groovy_guy, July 02, 2023, 10:23:34 AM
groovy_guy
Hi I'm wondering if anyone can help me figure out what is wrong here. I recently built a dual buffer using the Klon buffer schematic. I used the TL072 to build 2x buffers in 1. When I connect the power (DC 9V) it starts to smoke. I'm pretty sure it's coming from the op amp but not certain. This happened the first time when the board was in the enclosure so I thought maybe something was touching the enclosure that shouldn't have been and causing a short. But I tried it on a second build without placing it in an enclosure and the same thing happened. I have attached my schematic. If anyone could spot any mistakes that would be appreciated. Otherwise I must have a short on the board somewhere that I haven't been able to spot.
Thanks
Your schematic looks fine. Smoking amp likely means too much current is being pulled. This could be from a shorted polarity protection diode or shorted decoupling caps on v+ or vb.
groovy_guy
Thanks for the advice. I finally worked out the issue. I bloody used 10k resistors instead of 100k for R5 and R9! Swapped them out and it now works perfectly with no smoke :)
I was going to suggest peer pressure, because it thought it would make it look cool?  But yeah, the resistors might do it too  ;)
It starts off with one or two and before you know it they're up to a pack a day.  :-)
Glad you got this sorted out.  In a recent build I mistook a NE5532 for a NE555 (ones an audio amp, the other a timer).  Not only did the transistor get hot but I touched the metal back plane (smooth move on my part) and it branded one of my fingers.
Quote from: gordo on July 03, 2023, 11:53:46 PM
I blame the parents.
JackSkellington
Quote from: groovy_guy on July 03, 2023, 10:20:47 AM
Excuse me, but why 10k resistors to the ground before the output make your op-amp smoke? It doesn't seem to me something so bad, or I wrong?
groovy_guy
Quote from: JackSkellington on July 04, 2023, 08:09:17 AM
I have no idea! But I don't question it. All I know is it works now ¯\_(ツ)_/¯
groovy_guy
#8
Quote from: mjg on July 03, 2023, 09:48:22 PM
Now I feel like a ciggy. This TL072 is a bad influence 😤
bluelagoon
Probably smoking cause did not read the Surgeon Generals warning on the pack of cigarettes
jwin615
Quote from: bluelagoon on July 10, 2023, 03:21:50 PM
Everyone knows opampa can't read. They just repeat what they've heard before. In one ear, out the other.
